Author Topic: 69 Z/28 Tach Stops at 4000 RPM  (Read 6627 times)
69z28302
« on: November 07, 2011, 11:42:50 PM »
Have just recently got the car running. A trip to the muffler shop and to get an alignment. Was out tonight a 'hit it" a couple of times and noticed the tach stopped at 4000 RPM.
Any Ideas?
Thanks CRG
69pace
    • TeamCamaro - Moderator
Re: 69 Z/28 Tach Stops at 4000 RPM
« Reply #1 on: November 08, 2011, 03:22:42 AM »
Maybe the needle has a flat spot. If you open the pod cover can you manually move the needle beyond 4000?
LM69Z28
« Reply #2 on: November 08, 2011, 04:57:56 AM »
Problems ...............these are great folks and did a fantastic job on my Z's original 7K tac. http://www.tachman.com     First place I sent it to, Instrument Services in Chicago totally screwed it up and could have cared less since they already got my $'s
good luck!
LM69Z28 ;)
69z28302
« Reply #3 on: November 08, 2011, 11:15:22 AM »
Thanks.  I'll chk that 69 Pace. If I have no results I'll pull it and send it to the Tach Man.
Stingr69
« Reply #4 on: November 08, 2011, 07:30:45 PM »
Tach man did mine and it works perfectly.
-Mark.
69z28302
« Reply #5 on: November 26, 2011, 08:16:27 PM »
I took the tach out to checked it. It was hitting the screw on the face right at the 4 grand mark. Bent the needle out a little and now it works fine.
69pace
« Reply #6 on: November 28, 2011, 09:18:34 PM »
Love the easy ones
