Author Topic: Body Plug list or diagram?  (Read 6341 times)
MyRed67
  • SZZLN 67
« on: October 26, 2011, 05:31:28 AM »
  Is there a list or diagram somewhere for all the Body Plugs on a first Gen. Camaro?   I see most suppliers list 12 in a set, but I do't think that includes the 2 - 1/2 in. plastic ones for the top of the Cowl.   And I have one that's a 1 in. rubber part # 4802102  I think came from somewhere in the Firewall, that is also not in the set.  I think I have all of the originals, but some of them were out of the car before I started working on it.  They were in a box in the trunk with some other misc. parts.  What I can remember;
     2 -  1/2 in. plastic in top of cowl (not in set)
     2 -  3/4 in. rubber, 1 in each Rocker Panel brace behind Kick Panel
     4 -  3/4 in. plastic, 2 in each rear Outer Wheelhouse (front and back)
     4 -  1 in. plastic, 2 in each Trunk Floor drop-off
   So, I have 10 in set here what am I missing/
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
Jesse James
  • 24 Years in the making and it's almost done.
Re: Body Plug list or diagram?
« Reply #1 on: October 30, 2011, 11:55:45 AM »
Ya don't forget the two under the back seat bottom cushion assembly too. I got the full plug set and I am missing those as well at the firewall and top pf cowl plugs too. Aggravating.
1968 SS350 (L48) 350/Tremec TKO 600/12 Bolt w/Powertrax. I restored my first car the way I wanted it done, not the way some judge at a car show would insist it be done. I am gonna be the one driving it, not them. I had no idea it would take 24 years and oh so much money, but I did it.
JKZ27
« Reply #2 on: October 30, 2011, 01:21:34 PM »
I think there is a 1" plug in the firewall to fill the unused speedo cable hole, depending on transmission.
John
John
68 RS Ash/Ivy Gold 327EFI M20
« Reply #3 on: October 30, 2011, 10:39:28 PM »
yep
MyRed67
  • SZZLN 67
« Reply #4 on: October 31, 2011, 02:31:04 AM »
  OK, here's an updated list,    I have the one that's a 1 in. rubber part # 4802102  I think came from somewhere in the Firewall, that is also not in the set.  I think I have all of the originals, but some of them were out of the car before I started working on it.  They were in a box in the trunk with some other misc. parts.  What I can remember;
     1 -   1 inch Rubber part #4802102 goes in Firewall in unused speedo-cable hole.(not in set)  I have !
     2 -  1/2 in. plastic in top of cowl (not in set)  I have !
     2 -  3/4 in. plastic, 1 ea. side under back seat
does this look complete?
1967 Camaro  LOS  11A
67 RS Ragtop
« Reply #5 on: October 31, 2011, 02:48:39 AM »
I may be wrong,but if you have a vehicle with rear antenna, the front piercing also gets plugged (for cable routing for standard front antenna). At least it's plugged at my '67 in this manner.
69z28302
« Reply #6 on: October 31, 2011, 11:09:14 PM »
Anybody have a pic of the 'under the back seat' plugs?
