Author Topic: 67 camaro rs rocker panel molding set  (Read 8708 times)
jcfcamaro
« on: October 13, 2011, 10:53:50 PM »
I know a guy who has a set of rocker moldings for a rs  67 car, 6 piece, There in the gm package . He said he bought them new in 1991.   Did gm still make these in 1991 ??? or did someone else make them and put gm package on them ??? I guess what I'm wanting to know is ,are these as good as the ones that came on a 1967 or just a repo with gm's name on them??? and what are they worth???
Re: 67 camaro rs rocker panel molding set
« Reply #1 on: October 13, 2011, 11:13:55 PM »
What are the part numbers on the packaging?
jcfcamaro
« Reply #2 on: October 14, 2011, 12:12:02 AM »
not sure,  he said there in it
IZRSSS
  • Guest
« Reply #3 on: October 14, 2011, 12:37:54 AM »
Not sure what this means ???... but if you'd like your question answered, follow Ed's lead. Ask the seller for the part numbers on the packaging and post them.
jcfcamaro
« Reply #4 on: October 14, 2011, 12:50:43 AM »
Ok , will do .
jcfcamaro
« Reply #5 on: October 14, 2011, 08:47:23 AM »
ok , he didnt send all 6 but did show 3 or 4 of the #, here you go.  3912089 , 3912087 , 3912090 ,   rh 1.o7667034    can you tell me the other 2 or 3 #  that I would need or should be with the rest
« Reply #6 on: October 15, 2011, 12:48:55 AM »
3912087 is the front fender molding (drivers side).
3912088 is the front fender molding (pass side).
4229491 is the door molding (driver side).
4229492 is the door molding (pass side).
3912089 is the rear qtr panel molding (driver side).
3912090 is the rear qtr panel molding (pass side).
7667034 is a later part number issued sometime between 1976 and 1980.
jimbo67rag
« Reply #7 on: December 01, 2011, 01:57:52 AM »
Hi All    I have been off the site for far to long.  Just busy with life.  No excuse I know.  In 2003 I restored a 71 camaro and found a nos set of rocker panel mouldings in stock at my local GM dealer here in St Albert Alberta Canada.  I was shocked.  The parts guy told me that any of the older established GM dealers whos were around in the 60's, 70's would get large volume of the more common parts.  Needless to say i was pumped at the nos parts.
