Author Topic: Muncie gear oil  (Read 10120 times)
fireZ
Muncie gear oil
« on: October 13, 2011, 01:18:33 PM »
Anyone know where you can still buy Valvoline 80/90 GL-4 gear oil.I can only find GL-5 and have been told it has sulpher in it which is hard on the brass syncros
1968 Z28 LA Built
LIC # RPO Z28
69z28302
Re: Muncie gear oil
« Reply #1 on: October 13, 2011, 08:41:12 PM »
My buddy put this in his 66 Chevelle. It say's it's for yellow metals.
http://www.pennzoil.com/#/transmission-fluids-and-gear-oil/pennzoil-synchromesh-manual-transmission-fluid
68Zproject
Re: Muncie gear oil
« Reply #2 on: October 13, 2011, 09:01:02 PM »
I got the Valvoline at a local place called Knechts.  I'm sure they don't have them where your at, but I've seen it at almost all the parts places. O' Reilly's, Schucks.
68Z28
fireZ
Re: Muncie gear oil
« Reply #3 on: October 13, 2011, 10:35:43 PM »
i will have too make a trip across the border and see what I can find. Thanks
1968 Z28 LA Built
LIC # RPO Z28
fireZ
Re: Muncie gear oil
« Reply #4 on: October 14, 2011, 07:26:47 PM »
I was able too find the oil at a GM dealership. What is the best in a 12 bolt posi  rearend
1968 Z28 LA Built
LIC # RPO Z28
tmodel66
Re: Muncie gear oil
« Reply #5 on: October 14, 2011, 08:38:37 PM »
I put GM lube and posi additive from the Chevy dealer in my new rebuilt rear end. That's what Motive Gear recommended.
Daniel
fireZ
Re: Muncie gear oil
« Reply #6 on: October 14, 2011, 09:58:07 PM »
The same oil as tranny 80/90 gear oil from GM
1968 Z28 LA Built
LIC # RPO Z28
tmodel66
Re: Muncie gear oil
« Reply #7 on: October 15, 2011, 01:00:11 AM »
NO it's strictly rear end lube and be sure to get the additive if it's positive traction.
Daniel
fireZ
Re: Muncie gear oil
« Reply #8 on: October 15, 2011, 01:22:13 AM »
Sounds good I have the additive already just wondering what was the best rear end oil too use. thanks
1968 Z28 LA Built
LIC # RPO Z28
jeff68
Re: Muncie gear oil
« Reply #9 on: October 15, 2011, 02:36:03 PM »
I know you already found your trans oil, but you can also still get CRC Sta-Lube 85W90 GL-4 at NAPA.
For the rear end, you can use a 80W90 GL-5 oil & the GM posi additive.
fireZ
Re: Muncie gear oil
« Reply #10 on: October 15, 2011, 05:37:52 PM »
Thanks for that Jeff. Love the Ash Gold car
1968 Z28 LA Built
LIC # RPO Z28
jeff68
Re: Muncie gear oil
« Reply #11 on: October 16, 2011, 10:33:44 PM »
^^Thanks - right back atcha.  Rallye Green looks great on a 68.
