Author Topic: Could you get a cowl hood on a base 1969 camaro?  (Read 21228 times)
Re: Could you get a cowl hood on a base 1969 camaro?
« Reply #15 on: October 07, 2011, 06:31:04 AM »
thank you for the advice. would that be in the assembly manual, or where would I look to see about adjusting it? Also if it is not an adjustment issue, just an old original part, Stingr69, what is the part number for the actuator? thanks for the help as always fellas
restore-z28
« Reply #16 on: October 07, 2011, 12:15:00 PM »
If the issue is the solenoid that actuates the flapper door, below is a link for Heartbeat City. Maybe start with manually opening and closing the flapper door to ensure there is no binding.
http://www.heartbeatcitycamaro.com/store/product/13744/Camaro-Cowl-induction-solenoid--69/
Sonny
1969 Z28 Camaro, sold :-(
1970 Z28 Camaro
www.camaros.ca
Charley
« Reply #17 on: October 07, 2011, 01:27:14 PM »
Loosen the clamp that holds the solenoid and slide it far enough so the door opens all the way. Then tighten the clamp. Pretty simple when you look at it.
Stingr69
« Reply #18 on: October 07, 2011, 04:35:28 PM »
GM # 1114427. It is in the AIM under "ZL2"
I see the repros that have the part number embossed into the side and they claim it is like original. I have not seen that embossed number on an original GM piece but I have not seen them all so who knows. The GM ones I have seen did not have the number embossed on them.
-Mark.
« Reply #19 on: October 10, 2011, 03:56:19 PM »
I loosened the clamp and moved the actuator, where the door opened all the way. The thing I realized when it allowed the door to open all the way then it wouldn't close. So my question now is- Does the car have to be running to allow the actuator full motion, or should I be able to get a full range of motion with the car off?
« Reply #20 on: October 10, 2011, 04:03:21 PM »
Doesn't matter if the car is running or not; as long as the key is in "on" or "accessory" position, the solenoid will get 12 volts when the switch closes.
« Reply #21 on: October 10, 2011, 04:07:40 PM »
ok so the the key in either position it should have a full range of motion. I will try that
