Thank You John Mello, it if was a snake, it would bit me
Has anyone ever seen a set-up like this on a CrossRam Intake ?
Anyone have the Instruction Sheets from an out-of-the-box Edelbrock SBC STR-10 CrossRam Intake Manifold?
Anyone have a 1971 Edelbrock Catalog?
If so, anything in there anywhere about Edelbrock Conversion Kit # 2562 ?
A May '68 Hot Rod Mag Article 'Short Stack To Go' is all about the Edelbrock Crossram on a SBC.
15 Dyno pulls making comparisons, with a HP Chart in the article.
For 'Street Use'... ( 2 ) lowly List 1850 600 CFM Vacuum Secondary Carbs...
BUT... 'upfitted' with ( 2 ) Larger Diameter 3-Barrel Vacuum Diaphragm Housings !
1850 600 CFM Main Body has same Venturi & Butterfly Diameters as 3810, 4210, 4295, 4584, 4776, etc
2x 1-1/4" + 2x 1-5/16 Venturi & 4x 1-9/16 'Flies
It is right there in the original Edelbrock AMC STR-11 Crassram Intake Manifold Instructions.
Pair of 1850's were down only 3 HP compared to pair of List 4224 660 Center Squirters !
456 HP vs 459 at 6k on a SBC 350 in the 'Short Stack To Go' Article Dyno Chart.
The Holley List 4224 660's are the same VENTURI as 1850, 3810, 4210. 4295, 4584, 4776,
BUT the 660's have 4x larger 1-11/16" Diameter Butterflies... thus the additional 60 CFM.
A 660 Main Body is nothing more than an 1850 Body with a 1/16" 45 deg chamfer at the bottom.
Wonder what it says in the Chevrolet Version of the Edelbrock CrossRam Intake Manifold Instructions?
Anyone ever done or seen such a thing ?...
Black & White photoshop pic requires some modified Linkage, but looks really cool imho.
3-Barrel Pods and Parts are non-existent basically, but 3x2 can still be had.
3-Barrel Pods have a 4-Screw Lid, 3x2 Tri-Power Vacuum Diaphragm Pods have a 'better' 6-Screw Lid.T
They say all 3 types of Diaphragm Pods have the same 3-Screw to Main Body Mounting deal... I wonder...
The Throttle Shaft End Piece is different though for all 3 types, each one is it's own,
Standard Pod, 3-Barrel Pod (4-Screw Lid), and 3x2 Pod (6-Screw Lid),
each one has it's own Specific different Throttle Shaft End Piece afaik.
Larger Diaphragm Diameter, same vacuum signal, larger surface area, more opening force...
The fact that Holley used (2) Larger Diameter Vacuum Secondary Housings on the 3x2 Tri-Power set-ups
goes along with the 'idea' of also using them on (2) 1850 600 cfm 4-barrels on the crossram for the same reason, I guess.
