Author Topic: Original Windshield for '69  (Read 10632 times)
« on: September 30, 2011, 09:34:15 PM »
My unrestored '69 Z28-RS has the PPG SOLEX DUPLATE type windshield, with a '69 date on it, but apparently this is a replacement, not the factory installation?   It was in the car in '76 when I bought it...
For an original 'unrestored' car, with all other glass original, should I replace this windshield with a repro?
What is the best source for an original reproduction windshields?   Can you purchase with a correct date code?   US made windshield with correct thickness?  or a thinner foreign mfg?
Gary    69 Z28-RS
Re: Original Windshield for '69
« Reply #1 on: September 30, 2011, 09:47:36 PM »
Is all the other glass PPG?
I've seen a few Norwood '69s with PPG glass. I believe Pontiac used PPG. In production they didn't much care what was used.
IZRSSS
  • Guest
« Reply #2 on: September 30, 2011, 11:07:05 PM »
This company was recommended by Jerry M. They can also date code the glass for you. Like with anything else, research them first.
http://www.psautoglass.com/
MyRed67
  • SZZLN 67
« Reply #3 on: October 01, 2011, 03:58:56 AM »
  I can verify psautoglass.com I got a Dated Windshield there for my early '67 Coupe, it is right on.  Guys name is Mike Wimmer he is very knowledgeable on these date codes.  Located in Janesville, WI. just south of Madison.  I live right in the area, was able to save shipping.   My car also had all original glass, but windshield was  cracked.
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
« Reply #4 on: October 01, 2011, 04:52:36 PM »
IF the glass is not DOT marked it is an original, they started DOT marking glass in mid 69.
I have seen both LOF and PPG in 69's.
IZRSSS
  • Guest
« Reply #5 on: October 01, 2011, 05:10:55 PM »
Here's quite a bit of info referencing original glass...ever try decoding them?... barrels of fun.  :-\
http://www.camaros.org/glass.shtml#LOF
sixt9x33rs
« Reply #6 on: October 15, 2011, 11:59:52 AM »
My 69 Convertible built last week of April has PPG glass throughout.
x77-69z28
« Reply #7 on: October 15, 2011, 07:55:55 PM »
my 05a z-28 has LOF on one side and ppg on the other!
Oaklyss
« Reply #8 on: October 16, 2011, 03:49:53 AM »
Gary    69 Z28-RS
My 04A 69 SS has the same windshield. I always thought is was a replacement but now I am not so sure. All my other windows are Soft-Ray LOF Safety Flo-Lite NV-10 DOT. My windshield is SUNSHADE   SOLEX    [ PPG  ]  W688 DOT.
69 RSSS ZL-2 4 speed, mint unrestored 04A LA built-SOLD
1968 GTCS mint unrestored original paint
1972 AMX 401 4 speed, cowl induction, twin-grip, A/C, unrestored, original paint
1963 Oldsmobile Jetfire factory Turbo and Methanol injection, 4 speed, posi, 1 of 4 known to exist
« Reply #9 on: October 17, 2011, 06:52:52 PM »
William,  My car is a Norwood Production (09C) but NO ... No other PPG glass.  All the other glass (sides and rear) are:
Soft Ray,  Safety LOF FLO-LITE    AS-2    IV  Solid tempered
Gary
Charley
« Reply #10 on: October 17, 2011, 10:09:03 PM »
 I would leave it in. What type of sealant-gasket is holding it in ? Even if it was not orig I would much rather have a piece of glass that was installed in 69 or even 76 versus a repo.
MO
« Reply #11 on: October 18, 2011, 01:36:43 AM »
"Even if it was not orig I would much rather have a piece of glass that was installed in 69 or even 76 versus a repo".
Ditto...
« Reply #12 on: October 18, 2011, 05:34:09 PM »
Thanks Charley...   that's generally my personal opinion as well.  I really *hate* to use reproduction parts..  and I don't want to on this car, unless the CRG consensus is that I should.  I can get a supposedly-correctly colored and marked/dated 'reproduction' windshield for around $400 ... but I believe they are slightly less thick now than the factory windshields..
I suppose I will just clean this one up ..and maybe remove it and reseal/re-install  if necessary.
Gary
lynnbilodeau
« Reply #13 on: October 18, 2011, 11:51:15 PM »
Is it true the repops are thinner?
Charley
« Reply #14 on: October 20, 2011, 01:35:07 PM »
Ones I have used are thinner but it has been a few years.
