Author Topic: Speedo cable retainer clips.  (Read 17954 times)
srode
Re: Speedo cable retainer clips.
« Reply #15 on: October 21, 2011, 10:47:50 AM »
These are only used on 4 speed cars, not automatics?   I couldn't find a reference to these clips in the AIM fora 350TH.
« Reply #16 on: October 21, 2011, 02:18:49 PM »
Only used on Muncie 4-speed cars (pass. side speedo connection).
« Reply #17 on: October 26, 2011, 04:04:39 PM »
Even though it's not Perfect, it is much better than the "off the shelf" version.
lynnbilodeau
« Reply #18 on: October 29, 2011, 03:19:15 AM »
Ok, got the ones from classic muscle.  I am sure I can make them work, but they look just like the "typical repro" above, so not really a match, but at least can be made functional.
Are the HBC ones any better?
« Reply #19 on: October 29, 2011, 04:28:15 PM »
No, they appear to have a little more of an arc, however it looks as though they came from the same die as the forms of the lip on the end are the same along with the other details.
Here is a quick sketched and dimensioned Oblique, well sorta... my mechanical drawing skills leave much to be desired...  :P.
lynnbilodeau
« Reply #20 on: October 31, 2011, 02:30:07 AM »
Much to be desired or not, still quite helpful, especially considering I don't have even one original to use as a model.
Thanks.
« Reply #21 on: October 31, 2011, 03:10:05 PM »
None of the photos above show the correct (uninstalled) configuration of the "legs" of the clip. Photo below shows a similar type of clip, used on '63-'67 Corvette "eyebrow pads" on the instrument panel; you squeezed the "wings" on the clip together with needlenose pliers, and that expanded the "legs" behind the hole, retaining the clip. Once the clip is installed and then the wings are "un-bent" to be removed, most of that feature is lost.
scoop
« Reply #22 on: November 16, 2011, 03:25:49 AM »
What is HBC
tmodel66
« Reply #23 on: November 16, 2011, 03:43:25 AM »
What is HBC
HeartBeat City   Just another parts place.
