Author Topic: 68 coil bracket w/ cowl plenum  (Read 4518 times)
70L34
« on: September 24, 2011, 11:01:57 PM »
Hi all, is there any special coil bracket required for the cowl plenum option on a 1968 302? My coil seems to be interfering with the air cleaner. Thanks, Tony
Re: 68 coil bracket w/ cowl plenum
« Reply #1 on: September 24, 2011, 11:16:50 PM »
I'm not aware of any difference in the coil bracket from std. air cleaner to cowl plenum. Just curious if your coil is bottomed out in the bracket? Assume your interference is bottom of cleaner base to coil wire/coil?
70L34
« Reply #2 on: September 24, 2011, 11:18:46 PM »
Hmm, not sure if the coil is bottomed out or not. I'll check. Thanks!
GaryL
  • Marilyn and me
« Reply #3 on: September 26, 2011, 04:11:08 AM »
Isn't the bracket slanted more for the cowl air cleaner than the open element?  It is for the '69 model.
Gary
