Author Topic: Low Oil Pressure Indicator  (Read 3536 times)
Dusk_Blue_Z
« on: September 13, 2011, 03:26:08 PM »
Can someone tell me at what PSI does the 'Oil' light come on in the dash?
Thanks, Nick
1969 X77 01B 51 51 flat hood
tmodel66
Re: Low Oil Pressure Indicator
« Reply #1 on: September 13, 2011, 04:05:33 PM »
I think it's around 7 pounds if I remember correctly.
« Reply #2 on: September 13, 2011, 05:54:02 PM »
There are several variables, but on average, the light will come on around the 4 to 5 PSI range. Chevy engines require approx 1 PSI for every 100 RPM, so if you're at a 700 RPM idle you "should" have an absolute minimum of 7 PSI oil pressure. Anything lower than that and the lamp will start to flicker. If it's really low (around 4 to 5 PSI), the lamp will stay solid.
Dusk_Blue_Z
« Reply #3 on: September 13, 2011, 06:07:23 PM »
Great, thanks for the info.
