Author Topic: Template for holes in deck lid for 1969 RS/SS Spoiler  (Read 9657 times)
hdptsr
« on: September 11, 2011, 03:02:17 PM »
Does anyone have a template for a 1969 RS/SS holes in the deck lid for the spoiler?
Lane 68
Re: Template for holes in deck lid for 1969 RS/SS Spoiler
« Reply #1 on: September 20, 2011, 03:48:10 AM »
You can get a set of templates from Steve's Camaro...they are reproductions of original...they are accurate.
Lane
Mark
« Reply #2 on: September 20, 2011, 05:57:02 PM »
Just make sure your reproduction emblem (if thats what your using) matches the template.  Pins on repro emblems have been know to be off from the originals.
Theres a drawing in a post around here showing the amount the emblem moved, think its 3.44".  All pin holes moved forward the exact same amount.  Make a template of your existing holes and slide it forward that much.
http://www.camaros.org/forum/index.php?topic=8171.0
Same deal with the spoiler, repro ones have the studs sticking out in various different angles from true 90 degrees from the bottom face of the spoiler.  Stick the studs through a sheet of cardboard, trace the bottom outline of the spoiler on the cardboard, cut it out, find the center and align it so the little nbs on the back of the spoiler, not the smaller mounting base, are flush with the back edge of the trunk lid, mark and drill your holes.  Drill the holes slightly larger than the 1/4" studs.
« Last Edit: September 21, 2011, 12:08:25 AM by Mark »
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
IZRSSS
  • Guest
hdptsr
« Reply #4 on: January 13, 2012, 04:09:40 PM »
Mark do you have a template for the rear spoiler for a 1969 camaro?  I looked up the link and it is no longer there.  Thanks Joe
hdptsr
« Reply #5 on: January 13, 2012, 04:18:15 PM »
Mark also do you still have the template for the rear deck lid emblem?
IZRSSS
  • Guest
« Reply #6 on: January 13, 2012, 08:11:42 PM »
Here's an entire thread dedicated to your question...http://www.camaros.org/forum/index.php?topic=3752.0
I can't remember who posted this pic, but its the best example I've seen for the deck lid emblem...
