Author Topic: Number/Size of Shims after adding Moog CA Shafts?  (Read 6772 times)
1967RS/SS
« on: August 31, 2011, 05:40:48 PM »
Just swapped my original upper control arm shaft to Moog K5250 shaft kit on my 67 for safety reasons.  I know these shafts add additional camber but is there a starting number and size of shims I should use to get me to the alignment shop?
1967 RS/SS L-48
Van Nuys 01C
Joseph
mopar346
Re: Number/Size of Shims after adding Moog CA Shafts?
« Reply #1 on: September 01, 2011, 02:28:14 AM »
Start on a LEVEL FLOOR, take a 2 foot level and lay it against the tire (sidewall) 90 degrees from the ground (up and down), use the shims necessary to get the bubble in the center or just slightly to the inboard line. I would double check my toe with a tape measure getting it 1/8-1/4 inch tighter in the front (toed in). This should be a safe driving setting to get it to the alignment shop, but test drive it for stability and drive straight to the shop at a moderate speed. I will usually double check my settings 3 or 4 times just cause I'm anal and I kinda pride my self on how close I get it.
1967RS/SS
« Reply #2 on: September 01, 2011, 02:33:40 AM »
Thank you sir!
1967 RS/SS L-48
Van Nuys 01C
Joseph
mopar346
« Reply #3 on: September 01, 2011, 02:41:35 AM »
My pleasure!
Good luck.
