Author Topic: Firewall wiring harness - under or over?  (Read 7258 times)
srode
« on: August 29, 2011, 09:36:06 AM »
1969 Camaro Pace car - what's the correct original wire harness routing - under or over the wiper motor?  Also, are all the looms (cowl flapper, coil, starter etc) bundled and taped together at that point or are they separate?
Re: Firewall wiring harness - under or over?
« Reply #1 on: August 29, 2011, 02:40:05 PM »
The harness goes above the wiper motor, and through the plastic wire trough on the way to the passenger side; the ZL2 wiring is as shown in the Assembly Manual (section ZL2, sheet A5).
srode
« Reply #2 on: August 30, 2011, 12:42:51 AM »
Thanks John, that helps.  I assume it goes under the booster and not over correct? Any chance someone has a picture of this to reference too?
IZRSSS
  • Guest
« Reply #3 on: August 30, 2011, 01:07:10 AM »
srode
« Reply #4 on: August 30, 2011, 01:16:55 AM »
Perfect, Looks like under the booster for the main harness, I'm ready to route them.
LM69Z28
« Reply #5 on: August 30, 2011, 11:09:49 PM »
Any difference between the original ZL/2 wiring harness and the new made or repros?
Michael Kellogg
LM69Z28
L78 steve
« Reply #6 on: September 02, 2011, 02:31:53 PM »
The ZL/2 replacement harness from Factory Fit is spot on.
69 Z/28 Dover White. SOLD
LM69Z28
« Reply #7 on: September 02, 2011, 05:57:29 PM »
I saw a pair of the fuse box connectors for the ZL/2 hood harness (the ones from the box through the firewall) that had and extra set of wires from each plug that goes into the fuse box and these wires had a plug-in clip at the ends to attach more wires?
Comments.........
LM69Z28 ;)
« Reply #8 on: September 03, 2011, 03:18:24 PM »
<<I saw a pair of the fuse box connectors for the ZL/2 hood harness (the ones from the box through the firewall) that had and extra set of wires from each plug that goes into the fuse box and these wires had a plug-in clip at the ends to attach more wires?
Comments......... >>
That's correct - those are piggyback connectors so you can connect the rear defogger with ZL2; photo below shows my original '69 with ZL2 and C50.
LM69Z28
« Reply #9 on: September 03, 2011, 11:15:17 PM »
John Z
Well how cool is that! "Knowledge is Good"
Thanks for clearing that up for me.
Michael Kellogg
LM69Z28 ;)
