Author Topic: Sway bar sleeves  (Read 14504 times)
Boston14
Sway bar sleeves
« on: August 27, 2011, 02:58:44 PM »
My 1969 ragtop  is an 11D (early) car.  I am in the process of a complete subframe restoration.  Does anyone know a vendor that carries the sleeves and clamps (AIM UPC3  A5) for the sway bar that go just inboard of the sway bar bushings and brackets?  Here are a couple of pictures of my sway bar.  Thanks.
boston14
boston14
1969 SS/RS 350 Convertible
tmodel66
Re: Sway bar sleeves
« Reply #1 on: August 27, 2011, 03:19:10 PM »
I have looked for these but I can't find any.  Everybody I ask at the parts houses don't know what I'm talking about.
Daniel
IZRSSS
  • Guest
« Reply #2 on: August 28, 2011, 02:20:24 AM »
Have you tried Firewheel Classics (800-711-0125)? Here's their outer bushing & bracket. Unfortunately they don't have any information on the "inboard" parts. Who knows, maybe they do have them. If not maybe they can point you in the right direction.
Charley
« Reply #3 on: August 28, 2011, 03:32:01 AM »
What's wrong with the ones in the pic ?
Boston14
« Reply #4 on: August 28, 2011, 01:33:47 PM »
Marty,  I am looking for the sleeves and clamps on the inboard sides of the sway bar bushings and brackets. Thanks anyways  :)
Charley, I guess I was just looking for an easy way out (instead of restoring them).  What was the original finish on the clamps? Thanks.
boston14
IZRSSS
  • Guest
« Reply #5 on: August 28, 2011, 02:07:25 PM »
I'm guessing the "Inboard" clamp & sleeve shown in your bottom pic (left) is the one you are talking about? I have seen similar clamps in Firewheel Classics catalog & the sleeve looks more like a urethane wrap.
169INDY
« Reply #6 on: August 28, 2011, 07:17:34 PM »
Those will clean up fine.
Disassy with care, clean rubber with soap and water, light degreaser, solvents usage should be minimized and dress with protectant.
Unwrap - unbend clamp, degrease in solvent tank & power-wire brush the steel clamps, preserve via your favorite method.
blast?, Boeshield natural steel, prime & paint? or plate (Clear zinc) * it seems they were orig natural. (I chose the incorrect method of clear zinc, mine look good & I drive my car)
Clean up hardware via plating or blasting or plating Phosphate bolt and clear zinc Nut & lockwasher, or, purchase NEW (Replacements) from AMK.
Reference: The 69 AIM UPC 3 Sheet A5, Staiblilized Shaft, View A Items 10 thru 14.
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
« Reply #7 on: August 28, 2011, 09:01:26 PM »
To add to what Jim said, if the rubber is hard there's fix for that. Soak the rubber in Lestoil for a few days they will sften up like new. Leave them in too long and they turn to mush.
Dave69rag
« Reply #8 on: September 04, 2011, 04:49:22 PM »
 Over the past few months, I have been collecting the parts to rebuild the front of my 69.  I know that I found a replacement set of the sleeves someplace. (they were repos not NOS GM) If you have not found them, let me know and I will try to figure out where I got mine from.
tmodel66
« Reply #9 on: September 05, 2011, 12:35:18 AM »
If you don't mind go ahead and find out where you got'em and post or PM me. I need a set as one of mine was missing so I can't just restore mine.
Daniel
IZRSSS
  • Guest
« Reply #10 on: September 05, 2011, 02:03:27 AM »
On the link below, click on the Image - Part No. MOG K5227. Next link enter the same part number (K5227)under Part Number Look-Up, then key the Part Number on the next link & you'll finally get to the pic. (Sorry for taking the scenic route but for some reason the pic link failed to post). If all else fails, give them a call...800-568-4761.
http://www.woodys-auto-supply.com/search.asp?stext=K5227&x=18&y=15
Dave69rag
« Reply #11 on: September 05, 2011, 03:56:39 PM »
« Reply #12 on: September 06, 2011, 08:32:42 PM »
11D Early... did they have the locators or not?
I thought the introduction was later, however I could be wrong.
tmodel66
« Reply #13 on: September 06, 2011, 10:04:14 PM »
Thanks for the link Dave.   What could I use for the grommet?
Daniel
Boston14
« Reply #14 on: September 07, 2011, 01:02:35 AM »
I am second owner of the 11D.  The car was never restored before I bought it in 1975 and had about 95% of it's original parts.  It has sat in my garage untouched until I started the restoration in January of 2010. The pictures in my post are of the sway bar as I received it and I am pretty certain factory original for the car.  BTW I labeled the pictures backwards, right is left and left is right....... whoops there goes the mind again  :).
boston14
boston14
