Author Topic: solenoid  (Read 8858 times)
sebastien
solenoid
« on: June 11, 2006, 02:23:58 AM »
What is the purpose of the wire between the positive of the coil to the "R" of the starter solenoid? ???
Sebastien 68  327 rag top
Re: solenoid
« Reply #1 on: June 11, 2006, 02:54:48 PM »
During normal operation, the coil gets 7-8 volts through the cloth-covered resistance wire that feeds it from the ignition switch, which improves point life. During cranking while starting, the wire from the "R" terminal on the solenoid to the (+) coil terminal feeds a full 12 volts from the solenoid to the coil, bypassing the resistance wire, providing more voltage to the coil for starting. When the engine starts and the solenoid disengages, the coil (+) is again fed by the resistance wire.
sebastien
Re: solenoid
« Reply #2 on: June 11, 2006, 06:53:12 PM »
Thank you for the response John.I just bought "the Breakerless conversion system" from Rick's.And in the Instruction it is mention
this ignition is designed to work with a ballast resistor.
There is no ceramic resistance or anything else to add since the resistance is part of that white wire.
Is that correct?
Re: solenoid
« Reply #3 on: June 12, 2006, 02:24:01 PM »
Is that correct?
Yes, that's correct - the cloth-covered white wire has the resistance required; previous to 1967, a separate ceramic-encased ballast resistor was used.
sebastien
Re: solenoid
« Reply #4 on: June 12, 2006, 05:28:54 PM »
It all makes sense now,thank you.
