Author Topic: 69 Key on... What dash lights light up?  (Read 6065 times)
69z28302
« on: August 11, 2011, 01:30:52 AM »
Its been awhile guys since I ve had this car running. My first car with console gauges. I need to know in the "ON" or start postion  what lights are on and go out when started
Forgive me
MRPENNYPKR
Re: 69 Key on... What dash lights light up?
« Reply #1 on: August 11, 2011, 04:12:14 AM »
The only light show I get is the "brake" light IF the parking brake is on, and the "Low Fuel" which only comes on and stays on IF the fuel is low.  The console gages will give bogus readings until the power is turned on and will then snap to the correct readings.  The owners manual only mentions that the generator light will come on and then go off, however that is replaced by your console gauge.
This is one case where no lights at all is good news.
Tony
69z28302
« Reply #2 on: August 11, 2011, 11:12:02 AM »
Thanks Tony. So theres no "Gen" light that comes on and go's out when started then? If this the case thats what I got . Nothing lighting up.
1971ls6
« Reply #3 on: August 12, 2011, 12:57:19 AM »
My gen lights up and then goes off, wondering the same?  If not supposed to light up, why would mine be coming on
69 Copo 12.28 @ 117.50 4spd on polyglas
71 LS6 vette 12.31@118 mph PSMCDR
« Reply #4 on: August 12, 2011, 02:01:07 PM »
Do you have factory console gauges? Those cars didn't have a generator light. Without factory gauges, you'll have a generator light.
« Reply #5 on: August 16, 2011, 11:34:28 PM »
Without console gauges all the lights come on when you turn the key through the start process except brake if it's off.
