Author Topic: 68 302 oil pan  (Read 16683 times)
gary
68 302 oil pan
« on: August 09, 2011, 10:23:50 PM »
Can anybody tell me how to identify an orginal 68 302 oil pan from the 69 302 pan and the replacements. I'm putting together my 68 302 motor and not sure if I have tje correct pan. Thanks
1968 Z28
Re: 68 302 oil pan
« Reply #1 on: August 10, 2011, 01:28:10 AM »
Gary....I have an original '68 302 pan but can't get to it right now....will try later tonight to get some photos.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
gary
Re: 68 302 oil pan
« Reply #2 on: August 10, 2011, 01:33:19 AM »
Thanks that would be great.
1968 Z28
Re: 68 302 oil pan
« Reply #3 on: August 10, 2011, 04:19:27 AM »
Hope these help...
Jerry G.
1968 Z28
Re: 68 302 oil pan
« Reply #5 on: August 10, 2011, 04:20:37 AM »
More...
Jerry G.
1968 Z28
Re: 68 302 oil pan
« Reply #6 on: August 10, 2011, 04:21:22 AM »
Last...
Jerry G.
gary
Re: 68 302 oil pan
« Reply #7 on: August 10, 2011, 08:37:52 PM »
Thanks alot Jerry.
    I will compare with the ones I have. Thanks again,  gary
gary
Re: 68 302 oil pan
« Reply #8 on: December 17, 2012, 12:22:52 PM »
Hi Jerry,
    You have been very helpfull to guys with question on this website. You answered some questions for me and also sent pictures to me . Thank you very much. Your 68 z/28 is a 7c car and mine is a 6d car. I would like to have some info from your car to see if my dates are in line. If possible would you send me dates of your exhaust manifolds. mine had headers on it when i got it and I have two sets but not sure how close on the dates they need to be. Thanks alot Gary
Re: 68 302 oil pan
« Reply #9 on: December 17, 2012, 12:44:41 PM »
Gary, what dates do you have? Yep, Jerry is one of the good guys! :)
Lot's of 68Z info on our build thread- http://www.camaros.net/forums/showthread.php?t=182584
gary
Re: 68 302 oil pan
« Reply #10 on: December 17, 2012, 03:07:40 PM »
Hello and happy hoildays,
    My dates are 3872730 RH D-18-8, E-8-8. The 3892683 LH C-4-8, D-1-8, C-20-8. Since Jerry car is only 3 weeks later I thought that would give me an ideal of which ones to use or look for some more. Thanks for your interest.  Gary
1968 Z28
Re: 68 302 oil pan
« Reply #11 on: December 17, 2012, 05:30:13 PM »
Hi Gary....Ho, Ho, Ho
Left - F-7-8 and Right E-21-8.  Hope this helps.
Jerry G.
gary
Re: 68 302 oil pan
« Reply #12 on: December 17, 2012, 05:34:44 PM »
Hi Jerry,  HO HO HO , Merry Christmas
    Thanks so much for the info. I think I have  manifolds about 3 weeks prior to those that will work just fine.  Thanks alot and happy hoildays.
Since you car is so close in date as mine  I may be emailing you again if in question about anything. Thanks Gary
lynnbilodeau
Re: 68 302 oil pan
« Reply #13 on: December 30, 2012, 12:14:30 AM »
I believe 68 and 69 Z pans are the same.   Here is a tutorial on diferences between originals and the ones that are still available over the counter for under $100.
http://www.camaros.net/forums/showthread.php?t=178450
gary
Re: 68 302 oil pan
« Reply #14 on: December 30, 2012, 02:03:05 PM »
Thanks for the info.
