Author Topic: seatbelt cleaning  (Read 14546 times)
69ZX77MP
seatbelt cleaning
« on: August 05, 2011, 12:43:22 AM »
Hi i just purchased a complete seatbelt set  for my 69z . All labels are there i want to clean them up any ideas woulbd be great thanks
1969 Z28 X77 Lemans Blue 03D
Re: seatbelt cleaning
« Reply #1 on: August 06, 2011, 05:43:34 PM »
See my reply HERE.
69ZX77MP
« Reply #2 on: August 07, 2011, 12:49:21 PM »
Thanks ED great idea :o
sixt9x33rs
« Reply #3 on: August 09, 2011, 01:05:54 AM »
I soaked mine in Oxy clean with good luck.
69ZX77MP
« Reply #4 on: August 09, 2011, 10:39:02 PM »
Hi how long did you soak them and did you scrub them thanks Morgan ;)
« Reply #5 on: August 14, 2011, 06:00:16 PM »
With survivor belts I use oxyclean, I leave them overnight in scalding hot tap water, then hose them off and hang to dry... the results have been phenomenal.
69ZX77MP
« Reply #6 on: August 18, 2011, 11:30:29 PM »
Thanks Jim great cars you have outstanding thanks :o
sixt9x33rs
« Reply #7 on: August 19, 2011, 01:57:09 AM »
I learned the trick from James and like he said it works great.
« Reply #8 on: August 29, 2016, 07:15:36 AM »
James,
Do you take off the buckles first?
Thanks!
KJProX
« Reply #9 on: August 31, 2016, 02:09:21 PM »
I used a cap full Woolite on mine, same thing soak in gallon bucket of hot water over night, a lite scrub with a brush, rinse off, hang to air dry. I left the buckles on. The reason for the Woolite is it doesn't break down cloth fiber like more aggressive laundry type soaps do.
A cleaned one next to what it looked like before
The same dirty ones after
« Reply #10 on: September 02, 2016, 10:49:04 PM »
James,
Thanks!
No But I do snap off the covers and blow the buckles out.
The covers can be polished with plastic polish or swirl remover then plastic polish.
« Reply #11 on: September 03, 2016, 12:21:20 AM »
James,
Thanks!
When I did our deluxe seat belts with Oxy Clean (thanks James) Kurt when it was the buckle I extended the belt all the way so the buckle was not submerged. Next day rinsed and let dry and then extended belt webbing and did end missed from being out of solution. I did not want to have that knurled portion sitting in liquid. A couple after cleaning.
« Reply #12 on: September 06, 2016, 04:46:46 PM »
Thanks guys!
« Reply #13 on: September 08, 2016, 05:50:09 PM »
I soaked the belt in the oxyclean solution and then pulled them out and scrubbed them with a soft brush and rinsed.
For standard belts, remove the plastic buckle covers *before* soaking. The oxyclean removed the color from the top of the covers and from several of the release buttons. The sun had faded the covers and cleaning apparently pulled out the oils/plasticizers that were keeping the color darker. The undersides were fine. I sanded the center section and removed the light colored plastic.
Here's a pic of an original and a cleaned one (both are blue). Not sure what to do about the textured sides.
fwiw - To remove the cover, insert 2 small screwdrivers down the sides closer to the buckle's opening and pry up.
« Reply #14 on: September 17, 2016, 06:00:24 PM »
Try some vinyl and or leather conditioner... or maybe Meguires #7
