Author Topic: K79 option  (Read 7737 times)
RPOZ11
K79 option
« on: July 31, 2011, 10:29:11 PM »
Could I ask you guys to discuss and define this option.
Most searches I do come up with A/C, TH400, or Z28 in relative fields.
Thanx
BTW, would it be worthwhile to add an RPO "code" category?
I am aware of the PDF list, but a place to discuss those...
« Last Edit: July 31, 2011, 11:17:55 PM by RPOZ11 »
VN Pacecar
Re: K79 option
« Reply #1 on: July 31, 2011, 10:59:48 PM »
Not much to it really. If you wanted a 42 amp alternator instead of the standard 37 amp, you could stipulate K79 on the option list. The only cars it wasn't available on were A/C cars and the Z28.
RPOZ11
Re: K79 option
« Reply #2 on: July 31, 2011, 11:10:50 PM »
OK.
Where would one typically find this installed?
396's?
SS-350 cars?
9560 cars?
Would a Transistorized Ignition fall into that category of alternator?
VN Pacecar
Re: K79 option
« Reply #3 on: July 31, 2011, 11:36:37 PM »
No, the 69 COPO 9560 TI installed from the factory used the 37 amp alternator. The 42 amp alternator was just another option available to any car (with the exceptions noted above).
Re: K79 option
« Reply #4 on: August 12, 2011, 03:41:07 AM »
In '67, the 42-amp and 61-amp alternators were actually available on the Z28 as an option. Starting in '68, you could only get the Z with the 37-amp alternator.
bc69
Re: K79 option
« Reply #5 on: July 08, 2014, 01:12:20 AM »
To revive this post a bit what alternator would be standard on a early 67 RSSS 350 a/c car?
Brad
RSSS
Petes L48
Re: K79 option
« Reply #6 on: July 08, 2014, 03:03:39 AM »
As was discussed in your "L48 alternator part number" thread, the 61 amp 1100750 for a car with air cond.  It was required for RPO C60
bc69
Re: K79 option
« Reply #7 on: July 19, 2014, 05:33:02 PM »
Did all 1100750's come with same fans and pulleys?
Brad
RSSS
