Author Topic: Brake hoses  (Read 9626 times)
melav8r
Brake hoses
« on: July 28, 2011, 02:59:31 AM »
Re: Brake hoses
« Reply #1 on: July 29, 2011, 04:12:28 AM »
I don't remember where I saw the post but it had a picture of those and said the ends were not correct.
Re: Brake hoses
« Reply #2 on: July 29, 2011, 02:18:58 PM »
As I recall, 60's brake hoses had a single crimp on the ends; when DOT regulations became effective, the brake hose test requirements changed, and new hoses had to have a double crimp in order to pass the DOT pressure test; that's the only kind you can buy today.
melav8r
Re: Brake hoses
« Reply #3 on: July 29, 2011, 03:27:49 PM »
Thanks Gents,
so the ends were single crimped on the originals, what about the markings?
sam
Re: Brake hoses
« Reply #4 on: July 29, 2011, 07:04:50 PM »
I believe they are pretty much spot on. The guys doing those hoses did alot of research on their parts.
Re: Brake hoses
« Reply #5 on: July 30, 2011, 02:07:45 PM »
In NCRS judging on Corvettes, we don't take a deduction for modern double-crimped brake hoses, as it's a safety item.
Re: Brake hoses
« Reply #6 on: July 31, 2011, 11:03:48 PM »
Here is the recent post from the past week. http://www.camaros.org/forum/index.php?topic=8353.0 Or scan down the page you posted and you will see the brake hose post.
I believe the hoses being used are Raybestos. InLiine Tube advertises front brake hoses that are supposed to be the same.
copo
Re: Brake hoses
« Reply #7 on: August 01, 2011, 11:24:30 PM »
The  Raybestos. InLiine Tube hoses are not the same as the original hoses. The original hoses have a square end on the banjo fitting, the InLlne tube and Raybestos hoses have rounded corners on the banjo fitting. The hoses in the auction have the correct square end banjo fitting.
Re: Brake hoses
« Reply #8 on: August 02, 2011, 05:39:04 AM »
I guess when I sell some more body parts I can spring for the hoses.  I just found my original back hose and I'll post a pic when I get a chance.
Re: Brake hoses
« Reply #9 on: August 08, 2011, 12:16:39 AM »
Steve Shauger
    • Vintage Certification
Re: Brake hoses
« Reply #10 on: August 09, 2011, 12:56:00 PM »
As John Z stated the long single crimp is assembly line correct. Later DOT regulations required the double crimp as a safety requirement. 68Zproject shows the correct original type crimp found on 60's built cars.
Steve Shauger
Re: Brake hoses
« Reply #11 on: August 12, 2011, 10:19:33 AM »
Our orig. 68 Z/28 rear hose cleaned up pretty decent especially the hose part with the red writing.
