Author Topic: 1968 SS350 Front Springs & Brake ID Tags/Tape  (Read 5238 times)
68 RS/SS Ragtop
    • My fquick e-garage
« on: July 23, 2011, 03:12:25 PM »
Ok, so I've re-assembled my 68 subframe. It's a L48 w/ C60 Ac. I purchased the coil springs from Rick's. I've searched for spring rate ID tags/ tape with no luck. Did 68's have ID tags on the springs, and does anyone make a nice re-production? From other info I've seen here I should be looking for YZ tags or YV Tags.
I also have disc brakes and have seen that the backing plate is supposed to have a CS sticker, does anyone know where on the backing plate this should be applied.
Thanks for any help you can offer.
Bob
Capt Bob
68 Camaro Convertible owned since 1980.
92 Z28- Who doesn't like a Hugger Orange 3rdGen
02 BlackBird #30- 1 of 2 convertibles built.
http://www.fquick.com/68_RS_SS_Ragtop
bowtie68iho
Re: 1968 SS350 Front Springs & Brake ID Tags/Tape
« Reply #1 on: August 08, 2011, 03:32:11 AM »
Contact Don Lightfoot in Ontario, Canada.  He does excellent reproduction tags, tapes, decals, stickers, etc.  He'll custom make things not available on the aftermarket.  I was very pleased with his spring tags, disc brake splash shield decals, and glovebox tire pressure decal.  I have used his work on my concours 68 RS/SS Convertible with an L48 and C60 A/C.
Wrap the leaf spring tape completely around the rear portion of the spring, just forward of the rear shackle.  The coil spring tape wraps once around the middle coil, with the excess (tab) toward the shock.  To be technically correct, you should use a tape cutter with a serrated edge to make cuts...that way, the tape will not have a smoothly cut edge (such as with scissors).  The splash shield decals go at the top, inside half of the shield, just forward of the upper ball joint.  Per Jerry MacNeish's Z28 book, one decal is black text on a yellow background and one is red text on a yellow background.  I don't have his book with me right now (I'm traveling), so I don't remember which side gets the black versus red text.
E-mail: don48@personainternet.com
Web site: http://www.angelfire.com/rock/69ss/frame.html
68 NOR SS/RS L48/M35 Convertible
Cordovan Maroon - Special Paint Exterior (black stripes)
Black Custom Interior
Silver Concours (Legends Class) at 2012 Camaro Nationals, Gold Concours at 2014 MCACN.
68 RS/SS Ragtop
« Reply #2 on: August 08, 2011, 12:20:22 PM »
Great stuff!!! Thank you.
Capt Bob
