Author Topic: Transmission Reverse Lockout  (Read 6582 times)
TX-302
« on: July 22, 2011, 04:07:35 AM »
Was the reverse lockout installed on all 69 Camaro Muncie Transmissions? Any documention avialble showing illustrations and/or operation explanation?
Thanks!
69 Z
Stingr69
Re: Transmission Reverse Lockout
« Reply #1 on: July 22, 2011, 11:39:37 AM »
UPC 7 in the assembly manual shows the back drive linkage to prevent starting the car without being in Reverse. I am not sure that is what you are asking. The shifter has a click detent for reverse but no "Reverse Lockout".
-Mark.
JoeC
« Reply #2 on: July 22, 2011, 01:19:45 PM »
rev lockout is what some call the rods and levers that lock the steering wheel when shifter is in rev
also turns on rev lights
there is a rod from the rev lever on the trans, to a crank, then 2nd rod to steering
some Camaro venders show them in their catologs
TX-302
« Reply #3 on: July 22, 2011, 01:27:31 PM »
Thanks for the clarification.
69 Z
Kelley W King
« Reply #4 on: July 22, 2011, 01:47:49 PM »
If you have headers it most likely won,t fit.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
« Reply #5 on: July 22, 2011, 04:22:22 PM »
Thanks!
The backdrive system was used on ALL 1969 Camaro 3-speed and 4-speed transmissions, so the shifter had to be in reverse in order to remove the ignition key; it's explained in the owner's manual.
TX-302
« Reply #6 on: July 23, 2011, 07:30:00 AM »
Thanks for all the feedback!
69 Z
