Author Topic: Hurst Handle Shifter Bracket  (Read 16351 times)
mikecio1
« on: July 21, 2011, 02:45:16 PM »
I am looking to find this bracket. It offsets the shifter over 1 3/4" than up 3 1/4 so that it is in the factory location.
I found it at Heartbeat City for 169!. That almost stopped my Heartbeat!
http://www.heartbeatcity.com/store/product/20646/Camaro-Hurst-shifter-handle-body--69/
Any help would be great
sam
Re: Hurst Handle Shifter Bracket
« Reply #1 on: July 21, 2011, 03:16:11 PM »
never saw one of those sold by itself. Call Camaro Specialities in East Aurora, NY. Bob may have something for you.
mikecio1
« Reply #2 on: July 21, 2011, 03:33:53 PM »
I shot him an e-mail.
Thnaks!
Flowjoe
« Reply #3 on: July 21, 2011, 03:52:07 PM »
I've never seen one solo before either - you can also try Pete Serio at Precision Pontiac ( http://www.precisionpontiac.net/ ) - He "wrote the book" on Hurst shifters ;D
mikecio1
« Reply #4 on: July 21, 2011, 04:29:07 PM »
Sent him an email too.
THANK YOU!
mikecio1
« Reply #5 on: July 21, 2011, 11:26:41 PM »
THANK YOU!
I sent Pete my question and the information I have. He wanted me to get "forum" opinion... will a 69 factory Hurst Shifter work in a 67 with no console?
FYI my transmission is a 69 Muncie
JoeC
« Reply #6 on: July 21, 2011, 11:46:00 PM »
the 69 stick is a different shape then the 67-68 stick
The aftermarket Hurst shifter for the 67-69 Camaro has the same offset except uses a bolt on chrome stick.
You can use a Hurst aftermarket shifter with or without the console and use the Hurst stick or use an original 67-68 Muncie stick made to fit the Hurst shifter
mikecio1
« Reply #7 on: July 22, 2011, 02:11:06 PM »
Will this work?
http://cgi.ebay.com/ebaymotors/HURST-3914340-COMP-PLUS-SHIFTER-MECHANISM-3914339-/280688764896?pt=Motors_Car_Truck_Parts_Accessories&hash=item415a5aa7e0
JoeC
« Reply #8 on: July 24, 2011, 12:40:47 PM »
yes the Hurst 391-4340 is the 67-69 shifter with no stick or ball but you can buy the 67-68 Camaro 391-4339 shifter with stick and ball for $235
The 1969 Hurst shifter with stick and ball is 391-7438
The chrome stick and ball is about $100  so the 4339 at $235 is better deal then the 4340 at $205
I'm not sure what you are trying to put together ? Do you want to use an original 67-68 Muncie stick with Hurst shifter?
mikecio1
« Reply #9 on: July 24, 2011, 07:35:31 PM »
I was just trying tp locate the shifter in the stock position.
69pace
    • TeamCamaro - Moderator
« Reply #10 on: July 25, 2011, 12:33:32 AM »
Did you check the Hurst site?
mikecio1
« Reply #11 on: July 25, 2011, 11:42:52 AM »
Way too much money there. I found it for 204 on ebay and 187 here http://www.streetsideauto.com/p/hurst-3914340/
3914340 is Hurst part #
JoeC
« Reply #12 on: July 26, 2011, 01:19:02 PM »
The first thing you should do is check out what Hurst parts you have.
You need to have the correct shifter, chrome stick, and mount plate to fit into the console.
Also need to have correct rods and levers for it all to fit correctly
The 67-68 chrome stick is 538-4106
The 67-68 mount plate is 117-5284
mikecio1
« Reply #13 on: July 26, 2011, 02:12:10 PM »
It is a non-console car.
mikecio1
« Reply #14 on: July 26, 2011, 02:16:18 PM »
I have been working with Bruce at Manchester Muncies. I have found him very helpful and knowledgeable. We have found a shifter that we believe will work for my application and it is in the process of being sent now. He stated he will stand behind everthing and if the shifter does not work he guarantees it and he will work with me on finding one that does.
I will let you all know how it turns out.
THANK YOU ALL FOR YOUR ADVICE AND SUGGESTIONS!
