Author Topic: 68' A Arm & Frame Dust Shields  (Read 5095 times)
joesauer
« on: July 21, 2011, 04:04:46 AM »
I'm installing new a arm dust shields (from Montco manufact.).  Looking for any suggestions or tricks to make installing the staples easier.  The replacement shields don't have holes for staples prepunched.
Re: 68' A Arm & Frame Dust Shields
« Reply #1 on: July 21, 2011, 03:45:21 PM »
Use the staple holes in your inner fenders as the template to make the holes in the shields, and make your own staples from 16-ga. steel wire (hardware store blister-pack item); many of the vendors supply stainless steel staples, and the factory never used stainless staples.
Petes L48
« Reply #2 on: July 21, 2011, 06:29:21 PM »
Sorry if I'm derailing this topic, but does anyone have a tip for a correct looking roll-over on the staples ends?  Is a "camel-hump" appearance correct?  I was thinking about using a pair of needle nose and rolling over, then push it down a little more into the rubber.
KevinW
« Reply #3 on: July 22, 2011, 11:06:56 AM »
Pete, that is exactly what I did, works great.
