Author Topic: Sealant between the heater box and the firewall?  (Read 6289 times)
BowtieSweden
« on: July 19, 2011, 06:41:11 PM »
What type of sealant is used between the heater box and the firewall?
Gus
Camaro SS Conv. -69
Impala SS Conv. -67
Camaro SS Coupe -12
Re: Sealant between the heater box and the firewall?
« Reply #1 on: July 20, 2011, 09:17:59 PM »
Gus
None on the inside box ( the dash mat becomes the gasket between the inner box and the firewall). The engine side blower housing had a bead of neoprene or vinyl plastisol sealer applied in its groove before it was attached to the firewall.
BowtieSweden
« Reply #2 on: July 21, 2011, 04:10:19 PM »
That was where I meant, in the engine compartment.
Any suggestions for products that are available today?
 / Gus
Camaro SS Conv. -69
Impala SS Conv. -67
Camaro SS Coupe -12
« Reply #3 on: July 22, 2011, 09:08:44 PM »
Almost any Black Body Sealer in a tube applied using a caulking gun. Ask at the Local Paint suppliers
68rs327conv
    • The build
« Reply #4 on: July 23, 2011, 01:23:49 AM »
I planned on using the 3m strip caulk when I put mine back on
68 RS Conv 327/210hp, Powerglide Factory AC
