Author Topic: 1967 Headlight Alignment  (Read 4385 times)
1sweet67
« on: July 09, 2011, 09:55:51 PM »
The headlights are crossing in the middle. Not sure what the previous owner was doing but it looks like the driver side headlight mount might be broken.
I can't seem to find anything online to show me how the headlights should me properly mounted.
If anyone has some pics or how-to instructions, it would be most helpful.
IZRSSS
  • Guest
Re: 1967 Headlight Alignment
« Reply #1 on: July 09, 2011, 10:34:26 PM »
The best advise I can give you is to purchase an Assembly Instruction Manual (AIM) for your '67. It can guide you through most problems. Using it as a reference you can determine where your problem is. Here is the 69...hope someone can post the AIM Headlamp Mounting page for your 67. If the housing assembly is okay, it might be as simple as adjusting the screws located at the headlight flange (#7 below).
Good luck and welcome!
Petes L48
« Reply #2 on: July 10, 2011, 12:47:20 AM »
1sweet67 - I sent you a message on this.  Look in your User Info block and click where it says you have messages.
1sweet67
« Reply #3 on: July 10, 2011, 08:27:22 PM »
Thank you SO much! This is so helpful!!
