Author Topic: rear diff build  (Read 7018 times)
LB67RSCONVERT
rear diff build
« on: July 09, 2011, 07:57:36 PM »
I am putting a 3.55 ring gear and pinion in my 8.25 ten bolt, it came with 2.56( I think) is there any thing that I should know about the swap? I set up the pinion to the specs with the gear set, and the ring gear is way off from the backlash setting.(about 100 thou.) any help on this?
Re: rear diff build
« Reply #1 on: July 10, 2011, 05:34:50 PM »
I'm not famlliar with the ten-bolt axles, but if they're like a 12-bolt, a ratio like 2.56 uses a 2-series carrier, and a 3.55 uses a 3-series carrier.
edwmck
Re: rear diff build
« Reply #2 on: July 12, 2011, 10:24:54 PM »
There s a spacer that is made, but not sure who sells it.
that you will have to use behind the ring gear to move it over, if you do not want to change to the 3 series carrier
Kelley W King
Re: rear diff build
« Reply #3 on: July 13, 2011, 01:54:48 PM »
The one from my GTO came from Summit or Jeg,s.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
