Author Topic: Z28 timing cover  (Read 7749 times)
wisemanz28
Z28 timing cover
« on: July 06, 2011, 01:34:14 AM »
I've been looking for a timing chain cover for my 1969 Z28. My car is a 1st week of September built car. What date would work for my car?  How far out can I go?
Stingr69
Re: Z28 timing cover
« Reply #1 on: July 06, 2011, 03:43:26 PM »
I don't know that anyone has ever definatively decoded all of the timing cover date codes. Some look like a typical julian based date code system but there are covers out there that the numbers are obviously not julian based. Nobody can see them once they are installed and painted anyway.
Not much help I know.
-Mark.
Kelley W King
« Reply #2 on: July 06, 2011, 05:34:03 PM »
Most parts on my car are 2 to 3 weeks before the build date. But for that part you might want the engine build date instead of the car date.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
« Reply #3 on: July 06, 2011, 06:59:21 PM »
The '69 Z/28 timing covers I've seen are dated like "4 69" for April, 1969, not in a Julian format; don't know if or when that dating format started or stopped.
« Reply #4 on: July 06, 2011, 07:42:08 PM »
Yep, have a timing cover off a 67 model year HP 327 and its stamped "3 67" (March, 67). All the ones I have seen are month and year. Seemed many were stamped and many were not!?!?  But as Mark mentioned identifying the date code would be extremely difficult once on the car. Heck, I could not  see one even with the timing cover off the car until I sanded the area to remove paint. Sheet metal stamping is not deep in nature.
« Reply #5 on: July 06, 2011, 08:18:42 PM »
Also note that the timing chain cover was installed at the engine plant, so you should look for a date before the engine build, not the car asembly date.
« Reply #6 on: July 10, 2011, 03:30:27 AM »
I have some that have a different format. I'll have to dig them out again....
« Reply #7 on: July 21, 2011, 12:20:27 PM »
Here's the March 67 one we have.
