Author Topic: Pressure Regulator Factory Application/s  (Read 7094 times)
BlackoutSteve
« on: June 05, 2006, 11:53:28 PM »
RPO-L48/B3 is the only place within the 1969 Assy Manual that lists the use of this pressure regulator.
Therefore, I was under the impression that only L48 350s had this fitted as shown.
A friend tells me any Camaro with front discs/rear drums use one as well. -Then why is it not in the RPO-J52 chapter?
Was it only the L48 optioned Camaros of 1969 that have this regulator? If not, what others?
Thanks. ;)
« Last Edit: June 05, 2006, 11:55:19 PM by BlackoutSteve »
Re: Pressure Regulator Factory Application/s
« Reply #1 on: June 06, 2006, 12:30:44 AM »
Steve,
This is an ongoing resarch project the guys are doing. You can read more about it HERE.
BlackoutSteve
« Reply #2 on: June 06, 2006, 05:06:41 AM »
Thanks Ed.. Interesting..
I guess I'll leave it off the car unless the rear wheels start locking up.. I'll fit one then and see what happens.  8)
