Author Topic: 1968 Z28 Camaro Engine, Frame, Brakes, Transmission - $7500 (Severance)  (Read 3825 times)
rodent
Not sure if it's been posted here or not :( I have no association with the item.
http://fortcollins.craigslist.org/pts/2468332505.html
It was on ebay back in 07, so looks like they still have it.
For future searches:
Quote
Complete 1968 Z/28 Camaro MO code engine for sale. This is from a car that was not numbers matching and was turned into a pro-touring street machine. It is a good running engine that appears to have been recently rebuilt. The frame, four piston disc brakes, and muncie four speed transmission is included. Also has power steering with deep groove pulleys. This is a very rare, hard to find engine.
Engine Block
front pad stamping 18N451710 VO524MO
block casting# 3914678 date E188
Heads
cast # 3917291 date E88 rh E188 lh
Carb
3923289-DZ List 4053 7A4 date
Intake Manifold
cast # 3917610
Exhaust manifolds
3872730 rh 3892683 lh
Alternator
1100814 date 7L8
Distributor
1111467 8D23
Transmission
18S425428 PH827 date case casting # 3925660
This set up is excellent for a 1968 Z28 clone or perfect if you have a real Z/28 needing the drive train. $7500 or may trade for a First generation Camaro needing restored or a 1968 Firebird. I will also consider a 1969-1970 Dodge Charger in trade. Note: rear end in picture is not included.
Severance Autobody--A First Generation Camaro Restoration Shop
970-686-2756
