Author Topic: 68 COUPE FENDER ON BACKORDER  (Read 6361 times)
paulsstuff
« on: June 27, 2011, 10:50:23 PM »
My car is ready for paint with one major problem. I have a 68 base coupe and the LH fender has been on backorder for two months, and now I'm told it will be at least mid-august before they get any in. They do have RS fenders in stock. I know the RS fenders have an extra brace inside for the hideaway headlights, and use different headlight pots as well.
 And I know this is probably a stupid question but will the RS fender work on my base coupe?
Re: 68 COUPE FENDER ON BACKORDER
« Reply #1 on: June 27, 2011, 11:49:55 PM »
Paul,
The 67-68 RS fenders have an extra mounting bracket welded to the fender for the RS headlight assemblies.  The fenders are the same otherwise.  In you can't wait for the standard fender, just remove this mounting bracket from the RS fender and you're good to go.
rat pack
« Reply #2 on: June 28, 2011, 12:32:23 AM »
Unlike the 69's these fenders are not as easily modified to fit both RS & non-RS cars. To make the RS fender work you will need a set of headlight mounting brackets from a non-RS fender and weld them into place after removing the RS h/l mounting bracket. The 67-8 RS fenders do not have both brackets in place............RatPack................
sd1968z28
« Reply #3 on: June 30, 2011, 01:51:39 AM »
where are you located i believe i have a nice rh fender maybe even an nos one if you need it bad?
« Reply #4 on: June 30, 2011, 02:09:55 AM »
joesauer
« Reply #5 on: June 30, 2011, 05:36:37 PM »
Have you considered another supplier?  Lots of vendors have fenders in stock, or if you like Goodmark, order one from them direct.
paulsstuff
« Reply #6 on: July 03, 2011, 02:35:59 AM »
 Thanks for the responses everyone. I managed to get one from NPD, although the shipping to Canada was almost as much as the fender.
