Nice looking car Mike...
Off topic to some degree I grant you, but could you relate what the dimensions of your TT II's are - dia/offset/backspacing etc. and what your tire sizes as pictured are for my info, as I would like to get a similar second set of wheels and tires soon and whether or not you have any rubbing or issues with them rubbing or hitting anything on tight turns or bumps when driving with your set up?
Also the steering wheel you have looks like a Grant or ?? other make. Is it a smaller diameter than the original OEM type or does it fit with the same dimensions as an original wheel?
Any info you care to share is much appreciated - Randy
Hi Randy, I got the wheels at wheelsforless.com
Product ID: VN5155761
Product Name: Torq Thrust 2.1 15x7 5/4.75 -6mm offset 3'76 backspace.
http://www.wheelsforless.com/detail.aspx?ID=5711The tires are BFG 225/60/15 from Discount Tire Direct.Com
I have no rubbing issues at all. My friend went with 235 and had some inner fender issues up front on his 69.
Yes the steering wheel is a grant. It seems to have the same dimensions as the stock one. I never had the stock one so I couldn't tell you for sure. But when I look at others cars it seems the same. Since the pic I changed the center cap. Grant makes one that looks more like a stock cap. Its red white and blue around a bow tie.
