Author Topic: Convertible Pump Wiring  (Read 4917 times)
victorsam
« on: June 26, 2011, 04:08:05 PM »
I am troubleshooting my tops failure to move.  It would move fine and then stop about half way.  I would wait a few minutes, then it would operate again.  I am thinking the circuit breaker would reset.  Yesterday after it stopped, I could not really get it going again so I began trying to track down the culprit.  The pump motor operates sporadically.  So starting there I need to check if it operating even while no hooked to the hydraulic lines.
My question regards the wiring of the pump itself.  There are 3 leads, one of which is ground.  Does 12 volts on one lead spin the pump in one directions while 12 volts on the other lead spin it in the other?  Should I be able to test this on the bench?
Re: Convertible Pump Wiring
« Reply #1 on: June 26, 2011, 05:07:24 PM »
Yep. Just put 12 Volts to the green wire to lower the top or 12 Volts to the red wire to raise the top. There's a complete troubleshooting procedure in the Fisher Body manual.
