Author Topic: 69 DZ Blocks  (Read 31947 times)
HOT3O2
Re: 69 DZ Blocks
« Reply #15 on: June 26, 2011, 09:12:15 PM »
Yes your probably right Sam. The quality control back in those days is not what it is today.
Rick
69 RS/Z28
crobjones2
Re: 69 DZ Blocks
« Reply #16 on: June 27, 2011, 01:52:51 AM »
My late November (68) built L48 is a 388 block. I also have a L48 block from a 69 full size wagon that is a 388 2 bolt main.
John
John
Are both your L48's from theTonawanda plant?
Chris
69 SS 350
Boston14
Re: 69 DZ Blocks
« Reply #17 on: June 27, 2011, 02:05:52 AM »
My 11D (68) L48 is a 388 block also. It is a Tonawanda cast and built engine. T1120HB
boston14
boston14
1969 SS/RS 350 Convertible
JKZ27
Re: 69 DZ Blocks
« Reply #18 on: June 27, 2011, 03:42:08 AM »
Chris,
I know the one in my 12B SS is, I'm 99% sure the other one is too but I'll check tomorrow.
John
John
68 RS Ash/Ivy Gold 327EFI M20
JKZ27
Re: 69 DZ Blocks
« Reply #19 on: June 28, 2011, 12:45:18 AM »
Yes, the other block is a Tonawanda. Strange though, looks like the cast date is I 26 8 and the assembly is T0212HN.
John
John
crobjones2
Re: 69 DZ Blocks
« Reply #20 on: June 28, 2011, 03:34:53 PM »
it appears that only the Flint assembled motors using this block  were 302s while the Tonawanda built motors are of the 350
I am curious if your blocks are 2 or 4 bolt? Mine is a 4 bolt
Kurt/Ed/John - does the above statement follow what is in the database?
Chris
69 SS 350
Re: 69 DZ Blocks
« Reply #21 on: June 28, 2011, 06:03:23 PM »
Chris,
Good observation, supported by the db. Also realize that Flint sometimes didn't make many of certain suffix codes, so that distorts it some.
Boston14
Re: 69 DZ Blocks
« Reply #22 on: June 28, 2011, 11:54:41 PM »
My 388 Tonawanda block is 4 bolt also. Tonawanda did not have the machines needed to produce 2.02"  intake valved heads, so they did not produce any 302 engines (at least that I have ever heard of). John Z or Kurt correct me if I am misinformed.
boston14
boston14
jdv69z
  • 69 RS Z/28 52E
Re: 69 DZ Blocks
« Reply #23 on: June 29, 2011, 12:37:33 PM »
So was the 388 block cast at Tonawanda? And shipped to Flint? Or cast at both plants?
Jimmy V.
Jimmy V.
tmodel66
Re: 69 DZ Blocks
« Reply #24 on: June 29, 2011, 01:16:23 PM »
boston14
Could you explain this.  All it takes is a different fly cutter to put in seats. The guides were the same size. The castings were basically the same in configuration.
Steve Shauger
    • Vintage Certification
Re: 69 DZ Blocks
« Reply #25 on: June 29, 2011, 01:28:37 PM »
boston14
This issue was discussed several years ago. I recall a few orig 302's built with the 388 block.
Steve Shauger
Re: 69 DZ Blocks
« Reply #26 on: June 29, 2011, 02:44:45 PM »
The chamber had to be clearanced for the flow. Tonawanda didn't have that tooling/station.
Re: 69 DZ Blocks
« Reply #27 on: June 29, 2011, 03:28:36 PM »
<<Could you explain this.  All it takes is a different fly cutter to put in seats. The guides were the same size. The castings were basically the same in configuration.>>
Photo below is a 461 chamber with 2.02/1.6 valves, but it's similar to the 462/291/186 chamber; note the added machining cut to unshroud the side of the chamber wall adjacent to the intake valve to optimize flow. Tonawanda only built small-block heads with 1.94/1.5 valves and no unshrouding cut, and didn't build any solid-lifter small-blocks; all solid-lifter small-blocks (and hydraulic-lifter L-79's) used 2.02/1.6-valves, and they were built only at Flint V-8. Flint had the transfer line station for the larger valves and the unshrouding cut, and Tonawanda didn't.
tmodel66
Re: 69 DZ Blocks
« Reply #28 on: June 29, 2011, 03:49:02 PM »
Thanks Kurt and John. Forgot about the chamber cut. I was thinking in terms of machine shop work and not assembly line work which is apples and oranges. Every step has it's own tooling.
L78 steve
Re: 69 DZ Blocks
« Reply #29 on: June 29, 2011, 05:07:01 PM »
There was also machining under the valve so not to neck down the flow on the 202's
69 Z/28 Dover White. SOLD
