Author Topic: Heater Core R & R 69 Z/28  (Read 8369 times)
LM69Z28
« on: June 19, 2011, 01:33:20 AM »
Any hints, tips, comments, suggestion or advice related to replacing the leaking heater core in our 69 Z.  Best place to get one or are the all the same and what other parts are required.
Thanks troops
Fathom Green LM69Z28
Stingr69
Re: Heater Core R & R 69 Z/28
« Reply #1 on: June 19, 2011, 05:46:05 PM »
You will need to loosten the fender and put a piece of wood in there to allow your hand to reach the fasteners that hold the heater core box to the firewall. Not a fun project I can assure you. I had the radiator shop pressure test the new core & reinforce my hose connections before I installed it because you don't want them to break off later.
-Mark.
« Reply #2 on: June 20, 2011, 02:42:26 PM »
You will need to loosten the fender and put a piece of wood in there to allow your hand to reach the fasteners that hold the heater core box to the firewall. Not a fun project I can assure you. -Mark.
The difficult "loosen the fender" trick isn't necessary to replace the core, but it is to replace the blower motor or to remove the blower housing.
« Reply #3 on: June 20, 2011, 04:13:58 PM »
I didn't know about 69's but the 68's I've had I did from the inside.
sam
« Reply #4 on: June 20, 2011, 08:41:41 PM »
Replace from inside the car.
Stingr69
« Reply #5 on: June 21, 2011, 05:36:42 PM »
How do you get the heater core box fasteners off? They do not have heads on the inside of the vehicle. They are pressed in studs. You have to get to the nuts on the front of the firewall to get the box off unless you are lucky enough that the previous owner changed the studs for bolts and captive nuts.
Unless I am getting too old?
-Mark.
x77-69z28
« Reply #6 on: June 22, 2011, 05:16:11 PM »
you take the nuts off on the engine side. you can get to all of them without removing the fender. flush it with clran water before you take it out, antifreeze on the carpet is bad,
Oaklyss
« Reply #7 on: July 02, 2011, 02:23:18 AM »
If you have the original Harrison core, don't replace it. Just take it to a radiator shop and they will repair and test it.
69 RSSS ZL-2 4 speed, mint unrestored 04A LA built-SOLD
1968 GTCS mint unrestored original paint
1972 AMX 401 4 speed, cowl induction, twin-grip, A/C, unrestored, original paint
1963 Oldsmobile Jetfire factory Turbo and Methanol injection, 4 speed, posi, 1 of 4 known to exist
vtfb68
« Reply #8 on: July 06, 2011, 09:20:49 PM »
Mike,
If you are still looking to get that repaired try Mac's in Bellflower 562 920 1871, They still do "old style" work as requested, R & Repair & R your original core for $200.
     Victor
68 08E LA RS Y2 749 L30 M35
