Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
General Discussion
Valve Cover Gasket
« previous
next »
Print
Pages: [
1
Author
Topic: Valve Cover Gasket (Read 3323 times)
IZRSSS
Guest
Valve Cover Gasket
on:
June 11, 2011, 11:20:54 PM »
What valve cover gaskets do you recommend...Rubber or Cork? My local auto store carries Fel Pro in both rubber & cork. The cork comes in 5/32, 7/32 & high temp...I read somewhere that cork conforms better to all the contours.
Tweet
Logged
GI JOE
Member
Re: Valve Cover Gasket
Reply #1 on:
June 12, 2011, 02:22:13 AM »
I use Mr. gasket cork... I found them better than the rubber a long time ago... (not sure if the rubber ones have improved)
I use a thin coat of blue Permatex sealer on the valve cover side with the cork and nothing on the engine side. That way they stay in place and when I adjust the valves on my BB they come off with the valve cover and go back on with no trouble of aligning the gasket and no oil leaks. GI JOE
Logged
SFC GI JOE - Airborne Paratrooper
68- L-78, M22, BV
69- L-78, M22, BV, Conv
IZRSSS
Guest
Reply #2 on:
June 12, 2011, 02:45:47 PM »
Thanks for you comment.
Logged
Print
Pages: [
1
« previous
next »
General Discussion
Valve Cover Gasket
