Author Topic: 1969 Deck Lid Emblem  (Read 17122 times)
nwbalddog
« on: June 01, 2011, 04:27:50 PM »
I noticed some 1969 have an emblem on the deck lid, while some do not. I currently do not and am also seeing it in assembly manual yet it does not specify if it was standard. I have the rear spoiler. Saw a few strings where this was mentioned, yet could not find my answer.
1969 Camarao Convertible
396/SS/RS/Auto
77thor
Re: 1969 Deck Lid Emblem
« Reply #1 on: June 01, 2011, 04:48:47 PM »
Someone correct me if I'm wrong, but I believe that the emblem was not used if a spoiler was installed.
« Reply #2 on: June 01, 2011, 04:52:19 PM »
If the spoiler was factory installed, the trunk lid emblem was repositioned forward 3.27 inches from the standard location. If it was installed by the dealer, they were supposed to reposition it like the factory but most didn't bother.
IZRSSS
  • Guest
« Reply #3 on: June 01, 2011, 05:43:11 PM »
Ed,
Off topic but can you please help me out here...If a rear spoiler was installed by the dealer, did they also install the stiffer torsion rod?
« Reply #4 on: June 01, 2011, 06:55:33 PM »
Quote
Not usually. Dealers just moved the torsion rod down to the next slot.
See THIS THREAD.
IZRSSS
  • Guest
« Reply #5 on: June 01, 2011, 07:31:47 PM »
The rear spoiler is the early built 69 version (roughly 59" X 4 3/4") and did not come with the thicker torsion rod. The spoiler is original to the car...it was the same color as the car before it was restored (the first and only time). Dealer installed certainly puts me a little more at ease.
I did not have issues with the trunk opening and closing. My problem was with the slightest gust of wind. It took all of about 1min to change the setting. Great advise on the link you provided...deep socket w/extention rod. I used a 6"...
I should have come to you sooner!
Thanks Ed.
KevinW
« Reply #6 on: June 02, 2011, 03:56:27 PM »
I have a 10B (1968 build) factory spoiler 69.  it has the short spoiler, thicker torsion bar and emblem moved up. :)
« Reply #7 on: June 02, 2011, 04:05:43 PM »
<<Someone correct me if I'm wrong, but I believe that the emblem was not used if a spoiler was installed.>>
All factory-installed spoiler cars had the rear emblem (re-positioned forward) and a thicker torsion rod. Photo below of my untouched original 02D '69 emblem.
IZRSSS
  • Guest
« Reply #8 on: June 02, 2011, 04:44:04 PM »
I think there was a thread somewhere that had a template or measurements for the rear emblem. If anyone know's where it is can you please post the link. Or...post a new one.
And...is the header and deck emblem the same?
« Last Edit: June 02, 2011, 06:00:32 PM by IZRSSS »
IZRSSS
  • Guest
« Reply #9 on: June 02, 2011, 04:44:49 PM »
You guys suck...  ;)
IZRSSS
  • Guest
« Reply #10 on: June 02, 2011, 09:11:35 PM »
Did another search and found this information from John;
     Re: 69 decklid emblem holes
« Reply #31 on: September 04, 2008, 09:55:02 AM »
On a factory spoiler car, the bottom straight edge of the emblem is 1-1/4" forward of the front edge of the spoiler, and the right edge of the "O" in Camaro is 4" from the edge of the lid.
Sorry Ed, I just noticed you post 3.27" from the standard position...
« Last Edit: June 02, 2011, 09:34:01 PM by IZRSSS »
mark x22
« Reply #11 on: June 02, 2011, 09:28:34 PM »
IZRSSS
  • Guest
« Reply #12 on: June 02, 2011, 09:49:37 PM »
Thanks Mark, this is the template I remember seeing. Problem is I am a General Contractor and only familiar with the standard measuring system. Is there something out there I can use for decimals?
I think I'll stick to John's measurements. Simple and clear-cut...
mark x22
« Reply #13 on: June 02, 2011, 10:07:57 PM »
4.18 = 4 3/16 .  3.44 = 3 7/16
IZRSSS
  • Guest
« Reply #14 on: June 02, 2011, 10:09:26 PM »
Hooowaaa.............Thanks Mark!!!!!!!!!!!
