Greetings,
Some visceral diecast hack and slash here. Grille surround and grille proper mated to bumper, though still need to grind away at shell to allow flush fit of entire assembly onto the bodyshell. 1:18 Hwy. 61 '69 Camaro chassis introduced and mated to 1:18 Yat Ming '69 Firebird shell. Much extra material on rockers of Hwy. 61 chassis allow this effort at repurposing to suit my needs here. Lane ten-bolt BOP (if they still had their own diffs.) rear end a finely rendered item, will be introduced here with welded-on extended fluid reservoir and electrically-powered cooler detail.
Though I very much like the interior floorpan detail on the GMP Trans Am Camaro chassis, on either it or the Hwy. 61 chassis I'm still responsible for fabricating double adjustable Koni shocks, the pair that are fitted laterally, racing front sway bar detail, a proper fuel bladder/cell housing, Watts link, differential cooler, etc., hence decided to 'do the Hwy. 61' option. Firewall filed back, feeling morbid about how much effort it will take to cut out the full rad. support and inner fender detail on the 1:18 Lane '68 Firebird to introduce onto the 1:18 Yat Ming '69 Firebird shell. A sharp eye may be able to make out that I've also fitted the interior to the Hwy. 61 chassis by cutting clearance for the driveshaft tunnel. A bit frightening to contemplate in total, but coming along. Thanks...
Mike K.
...very deft, very tight fit of Hwy. 61 '69 Camaro chassis. Note how it bobs out just behind the front wheelarches. Plugs for holes not needed to come. Much to add here.
...firewall filed back. Anticipate adding patched '68 Lane item less brake booster, plus heater core/heater block out plate. Lane items very nicely rendered.
...hood fit far better now, although know that for width, length and contour, nothing at all has been done with it.
...grille/bumper assembly largely complete but for putty and paint. Will scuff surface of chrome with brillo pad, for tough and high-quality Lane plating (with no less than a copper coat beneath it) will not yield to normal approaches towards removal. Expect to test coat rear '68 bumper to see what might be achieved. Grille surround to be painted blue as well! Strange appearance - like some Petty Charger before Petty Charger registered as an icon in anyone's head.
...nose in place, hood now flush, interior trim less driveshaft tunnel work spied.
Thanks for inspecting this post...
Mike K.
