Author Topic: 69 rear antenna with spoiler question  (Read 6707 times)
rooter11
« on: May 23, 2011, 03:37:21 PM »
I have seen a post that states that a spoiler will hit a rear mounted antenna. My question is will the spoiler hit the antenna if the antenna is in the down position ( original antenna )?
Big_Al
  • '69 L65 RS X11 Z87 Z21 713 40B DX1
Re: 69 rear antenna with spoiler question
« Reply #1 on: May 23, 2011, 04:55:08 PM »
Yes. If you use the '68 or early '69 spoiler (not as wide) it will make contact about a half inch in from the end. If you have a little antenna play, it can be pushed to the side enough to fully open the trunk.
'67 RS 327 convertible, '69 RS 350 coupe, '73 Type LT 350 coupe split bumper.
muscle joe
  • 1969 Camaro Z28 Butternut 1966 Chevelle L78
« Reply #2 on: May 25, 2011, 12:53:34 PM »
I have a rear retractable antenna and in the down position it does not hit the spoiler  Joe
Big_Al
« Reply #3 on: May 25, 2011, 08:46:56 PM »
Is your antenna an original stock part, Joe?
If we’re talking stock rear fender placement on a ’69 Camaro - mine measures 14 inches from center of antenna hole to back edge of fender - and a stock rear antenna - at just under 20 inches tall when fully retracted, (available for AM radio only) it will be too tall, even in the down position, to miss either spoiler available that year. A front antenna was required with a spoiler equipped car for ’68 & ’69.
rooter11
« Reply #4 on: May 29, 2011, 03:25:35 AM »
thanks for your help. guess I will go with a front mount.
