Author Topic: First Gen Hood Hinges  (Read 12286 times)
LM69Z28
« on: May 21, 2011, 05:02:44 AM »
Does anyone know if there is any difference between 67 to 69 hood hinges besides maybe manufactures or some stampings. I have one set that has N style stampings and another that has double AA stampings.
Were the 2 gen hinges the same as first gen?
Can anyone suggest what type of lube/grease to use on freshly restored phosphated hinges
Also looking for a set of springs (2) for ZL/2 hood, 26 coils.
Thanks for the tips etc.
LM69Z28
Re: First Gen Hood Hinges
« Reply #1 on: May 21, 2011, 05:58:33 PM »
No difference between 67-69. I recall the shade of phosphate varied from grey to nearly black, most likely an acceptable variation in the plating process. The stampings are likely specific to a supplier, which could have changed over the many years GMPD inventoried them. Even in production there may have been multiple suppliers.
There are only 2 springs, 1 for SS hood, 1 for all others.
LM69Z28
« Reply #2 on: May 21, 2011, 08:24:58 PM »
William,
Appreciate the response, suspicions confirmed. As to the springs I know 2 are require per hood and I require an original set of 2 hinge springs for the ZL/2 ducted hood 26 coils.
Thank you
LM69Z28
« Reply #3 on: May 21, 2011, 08:38:20 PM »
Same springs as the standard hood.
LM69Z28
« Reply #4 on: May 21, 2011, 09:48:05 PM »
Got it! I need to BUY a pair of springs (2) for the ZL/2 ducted Hood 26 coils, same as the standard flat hood............. anybody have an original pair FOR SALE!
or can anyone recommend a good repro. set that I can PURCHASE!
Thanks again
LM69Z28
scoop
« Reply #5 on: November 20, 2011, 05:05:34 PM »
I have a new set of NOS hood springs and hindges. The springs are the heavier ss spring. I paid 365.00 for them on E bay and I will sell them for what I paid. Still in the box.
LM69Z28
« Reply #6 on: November 22, 2011, 05:25:32 AM »
Scoop
Thanks anyway but those springs have too many coils for a cowl hood like our Z has.
Happy Turkey day to all :D
LM69Z28
z/27 camaro
« Reply #7 on: December 03, 2011, 07:28:59 AM »
William and LM69Z28....... its my understanding that you use the same springs for the SS and ZL 2 hoods.
both the SS and ZL 2 hoods are heavier than the flat hood and you need the stronger springs to lift it and keep it up.
i have seen cars that originally had a flat hood with flat hood springs, with an SS or ZL 2 hood added, keeping the flat hood springs and they need a stick to keep the hood open.
Stingr69
« Reply #8 on: December 03, 2011, 04:14:45 PM »
No. The SS has added cast pot metal chrome pieces that add significantly more weight to the hood assembly so the SS has a special spring. The ZL-2 hood does not have any significant added weight (insulation is very light and the same amount of sheet metal) so it uses a standard production spring. This is widely accepted as correct.
-Mark.
9T4Z
    • Gary's Camaro
« Reply #9 on: January 01, 2012, 11:15:39 PM »
I would agree. If you use the SS springs on the ZL-2 Hood, closing it is difficult and when opened it can pop right past the safety catch!
Gary 9T4Z
94Z rag blower 491 rwhp (now 505!)
69 Pace Car, 70RS,91Z,91RS
z/27 camaro
« Reply #10 on: January 02, 2012, 10:06:51 PM »
i stand corrected...did some research of my own and you gents are right. i had my information backwards.
i just bought some SS springs from GM last year......who would have thought. the standard springs are hard to come by i think....e bay.....
« Reply #11 on: January 07, 2012, 03:29:34 PM »
