Author Topic: Speaking 69 Z/28 Drive Shafts  (Read 4200 times)
LM69Z28
« on: May 12, 2011, 09:59:44 PM »
Spent an hour or so viewing all sorts of different topics and saw one on drive shafts but danged if I can locate it again. Redoing the M21 trans shortly,  leaks like a sieve since cheap gaskets were used a few years ago during a major overhaul. Two questions, can anyone recommend a good quality gasket set that's not made of "rice paper" and won't start to leak a few weeks after being installed and Jerry M calls for the DS to be natural metal in color, any paint mfg suggestions besides Seymours cast blast that would be concourse correct.
I can also shoot photos of numbers etc if anyone needs the info.  Norwood 02A X33 723 57 57 V0130DZ
LM69Z28
Direct: mjk302@earthlink.net
Re: Speaking 69 Z/28 Drive Shafts
« Reply #1 on: May 12, 2011, 11:08:24 PM »
correct would not be painted, there is no other way, cast blast will not age like the correct finishes and will end up looking out of place in a year or two... I use boeshield or cosmoline and am very happy with the natural finishes on the cars I restore. yes they are a little more maintenance, however they are correct and look/age much better than paint.
LM69Z28
« Reply #2 on: May 13, 2011, 12:07:38 AM »
Thanks for the info James...........Exploring all angels on this one!
Best
Michael Kellogg
LM69Z28
