Author Topic: 67 L30 Carb  (Read 5602 times)
67 RS Ragtop
67 L30 Carb
« on: May 12, 2011, 08:46:38 PM »
I've read the CRG reports on carbs, and understand that all 67's used Rochester QuadraJets, but it also states that Carter Manufactured them with the same numbers and coding, with the "Carter manufactured for GMC" on the main body. My question is - is it possible that the car may have been built with the Carter QuadraJet instead, as I have a 10B car, with the early Carter #7027202 DB with date codes between the engine and car assembly dates. ???
Re: 67 L30 Carb
« Reply #1 on: May 12, 2011, 08:55:40 PM »
Sure, they were both used simultaniously, but the only real way to verify which carb came on your car is to look at the CARB CODE on the POP. In the upper right corner it'll have either R (Rochester) or C (Carter).
67 RS Ragtop
Re: 67 L30 Carb
« Reply #2 on: May 13, 2011, 11:42:56 AM »
  Thanks Ed,
    Unfortunately, I have no POP, and the original owner can find no documentation - just wanted to be sure I was restoring too numbers correct, in the absence of documentation.
  GW
camaro cat
Re: 67 L30 Carb
« Reply #3 on: June 03, 2011, 04:28:58 AM »
My 10C LOS L-30 was built with a Carter carb.
Loren
Loren
1967 RS L30 10C LOS
1969 SS/RS L78 02D NOR
