Author Topic: Factory rear sway bar set-up, 1967  (Read 56016 times)
Re: Factory rear sway bar set-up, 1967
« Reply #45 on: September 27, 2014, 04:37:46 PM »
You're welcome, Max.
Below is a photo showing the holes in the rear subframe where the flat u-bolt goes through. The front of the car would be to the right.
« Reply #46 on: September 28, 2014, 05:01:28 AM »
Another vintage rear sway bar for an early Camaro, again from the Robert Lodewyk collection. The name of the manufacturer is unknown.
The width of the sway bar is 34" across and the vertical links appear to bolt through the side of the rear frame rails.
Looks like a Supertanium bolt connecting the bar to the vertical link...
A closer look at the clamps that bolt around the rear axle tubes and hold the sway bar in position.
« Reply #47 on: September 28, 2014, 05:05:05 AM »
Here's a side-by-side comparison of Robert's two different styles of aftermarket rear sway bars...
