Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
General Discussion
Original panels? Sail panel seam paint crazing
« previous
next »
Print
Pages: [
1
Author
Topic: Original panels? Sail panel seam paint crazing (Read 7932 times)
RC
Newbie
on:
May 29, 2006, 02:32:51 PM »
Looking at another ebay auction
http://cgi.ebay.com/ebaymotors/1967-Camaro-RS-SS-ORIGINAL-1-owner-Documented_W0QQitemZ4643963751QQcategoryZ6161QQrdZ1QQcmdZViewItem
The description says the car has all original sheetmetal. In the pics you can see that the paint in checked or crazed at the area of the sail panel/roof seam. This makes me wonder about replacement panel work.
The spatter paint that is NOT in the trunk also makes me wonder, but I don't know what a 40 year old trunk typically looks like. The spatter is clear on the piece that covers the fuel filler/trunk lock assms. Again, I wonder about panel replacement.
Is there history to say paint crazing at the sail panel is a frequent problem, even on original panels. I know my second gen camaro had cracking issues there.
Thanks for any and all comments.
RC
Tweet
Logged
CRG Member
Re: Original panels? Sail panel seam paint crazing
Reply #1 on:
May 29, 2006, 03:59:15 PM »
My all-original 69Z also shows some very light crazing and some show-through of tiny pits under the paint at the roof-to-quarter solder joint on the driver's side; this is quite common on original-paint cars. If you had seen the production process (open solder pots, applying it with hickory paddles and a torch, then grinding and pit-filling, all with the body moving at 70 per hour), you'd be amazed that solder joints lasted as long as they did in a joint that long.
Logged
sebastien
Member
Reply #2 on:
May 29, 2006, 07:56:11 PM »
John,with paint removed what color would be those solder joints ?gold(ish)?
Logged
Sebastien 68 327 rag top
CRG Member
Reply #3 on:
May 29, 2006, 10:52:12 PM »
The natural color of freshly-ground solder is like yellowish aluminum, although the assembly plant hot phosphate treatment prior to prime in the paint shop may affect its color.
Logged
sebastien
Member
Reply #4 on:
May 29, 2006, 11:24:27 PM »
once again thanks for those precious info John Z
Logged
Print
Pages: [
1
« previous
next »
General Discussion
