Hopefully tomorrow I will be able to arrange some of the pics into one post, but for now, here is a little more info; 1. yes, my intake has been modified; most of the carb mounting pad had been machined off, I don't know why. 2. my intake has absolutely no casting #'s, marks,stamps, nothing. 3. it has never been bolted down 'tight' to an engine, ( no washer markings)... There is a youtube video listed as "Trans Am 1968", even though it is clearly the 1969 season, I believe at Donnybrooke. There is about a 5 second piece that shows John Martin CLEARLY stroking the throttles on two inline Dominators.. Later Pro Stock gurus all tried to make IR Dominators work with no success, and all written articles said the same.. a 2" throttle will barely feed a ~500hp application. 360 cid Pro Stocks were probably close to 600 or better. I have seen pics of this intake with a "plenum adapter" on top, making for an extremely tall induction; again, probably too long of runner for a drag motor. Slabbed and sectioned Pro Stock heads like Booth, Arons, and Maskin and Kanners required major welding and epoxy- and most used the Edelbrock UR-18... My intake will never look completely original, and the fab work was not finished in time for the show, but it is a true T/A piece. I'm sure the crossram would have enjoyed a taller air cleaner, but one pic I've seen of a domed hood on a crossram Javelin still carries the super-flat airbox... I do appreciate all the discussions, tips, and ideas... ya'll are the best.. Ken
