Author Topic: Engine photos  (Read 168609 times)
crossboss
  • ^ New engine project
Re: Engine photos
« Reply #135 on: October 23, 2019, 02:12:47 PM »
Phat-
A true IR Dominator intake while using the larger 1150 cfm carbs can only feed a 350 cid engine @ 8,500 RPMs. The late Bill 'Grumpy' Jenkins was a master at making them work on a 331 cid drag engine. Yes, there were 'some' experimental 4500 series Dominators made, but proved to be unsuccessful. That said, the original sand cast IR Dominators, as you may recall were used on 302 cid engines for Trans-Am competition. Btw, there was never any big-block Dominator IR intakes made (regardless of brand) as I mentioned, not enough carbs to feed it. Fuel injection, and two Autolite 'B' 1425 cfm Inline carbs and the rare Weber 58mm carbs will feed the large big-block Weber IR type intakes….but that is a different topic.
1968 Olds 442 W-30
PHAT69AMX
Re: Engine photos
« Reply #136 on: November 13, 2019, 09:09:27 AM »
Sorry all...  way late responding...  yes...  at 9:41 in the previous video link is the underhood shot that's, yes, basically 'useless' as all that is visible is the air cleaner, not at all visible are the carbs or intake...  apologies
369
Re: Engine photos
« Reply #137 on: February 15, 2020, 10:08:20 PM »
Hi all.....can someone explain the thought process behind using the corvette radiator vs the Camaro stuff. I’m assuming that’s the reason a lot of guys were using the Harrison overflow can?
Re: Engine photos
« Reply #138 on: February 16, 2020, 01:15:19 AM »
The Corvette radiators were aluminum vs brass for the Camaro radiators, hence a little weight savings.
Re: Engine photos
« Reply #139 on: February 26, 2020, 02:41:37 PM »
10-4....that makes sense
rmbuilder
Re: Engine photos
« Reply #140 on: March 17, 2020, 05:11:30 PM »
From last week at Amelia Island.
Bob
Re: Engine photos
« Reply #141 on: March 20, 2020, 04:01:20 AM »
Thanks, Bob.  It looked like quite an impressive gathering of Penske race cars at Amelia Island.
crossboss
Re: Engine photos
« Reply #142 on: March 23, 2020, 11:22:43 PM »
Bob
SWEEEET! Thanks for sharing.
1968 Olds 442 W-30
MO
Re: Engine photos
« Reply #143 on: March 26, 2020, 03:52:20 AM »
Interesting header bolt configuration.
Re: Engine photos
« Reply #144 on: March 26, 2020, 10:15:38 AM »
Stahl style header style bolt pattern.  For round port heads or spread port heads.
crossboss
Re: Engine photos
« Reply #145 on: March 26, 2020, 03:06:23 PM »
Correct me if I am wrong, it appears there are 'spacers' between the heads and headers? Isn't this for the 'larger' exhausts to mate up...I have seen this before, especially for the mentioned round port/spread port heads, right?
1968 Olds 442 W-30
MO
Re: Engine photos
« Reply #146 on: March 27, 2020, 06:29:57 PM »
Thanks for the info. Are the heads already prepped or do you have to drill and tap yourself?
rmbuilder
Re: Engine photos
« Reply #147 on: March 30, 2020, 10:31:41 PM »
MO,
The porting of the cylinder heads of that period (Lockerman, Valley Head Service, etc) utilized a large, round, exhaust exit which greatly reduced gasket area. That created a gasket/header flange durability issue particularly in the two adjoining center ports. The solution was adapter plates attached to the head flange. with a revised fastener pattern for the header flange.
rmbuilder
Re: Engine photos
« Reply #148 on: March 30, 2020, 10:32:41 PM »
Flange
Re: Engine photos
« Reply #149 on: March 31, 2020, 11:50:59 PM »
I believe JohnZ said that the Aluminum radiator was also a much more efficient design which cooled better.
