Author Topic: 69 L48 Starter  (Read 15348 times)
IZRSSS
  • Guest
69 L48 Starter
« on: April 25, 2011, 10:08:50 PM »
I am trying to find a Starter for a 69 L48 (350/300HP) auto. The part # is 1108420. One other catch...it needs to be dated prior to 12A (1st wk of Dec. 68).
If you know of one, or have one please send me a PM.
Thanks guys!
« Last Edit: April 25, 2011, 11:21:40 PM by IZRSSS »
Re: 69 L48 Starter
« Reply #1 on: April 25, 2011, 10:34:16 PM »
I am trying to find a Starter for a 69 L48 (350/300HP) auto. The part # is 110840. One other catch...it needs to be dated prior to 12A (1st wk of Dec. 68).
Thanks guys!
Marty, are you sure about that number (110840)?    ???
Re: 69 L48 Starter
« Reply #2 on: April 25, 2011, 10:49:53 PM »
Should be 1108338 starter (Powerglide) or 1108420 (Turbo 350).
(Assuming you just made a typo and need the 1108420...)
IZRSSS
  • Guest
Re: 69 L48 Starter
« Reply #3 on: April 25, 2011, 11:02:52 PM »
I left out the 2 but I still had time to add it before time expired...
Thanks Paul & Ed!
« Last Edit: April 25, 2011, 11:28:36 PM by IZRSSS »
crobjones2
Re: 69 L48 Starter
« Reply #4 on: April 26, 2011, 08:54:51 AM »
Any idea when the change happened on the production line?
Chris
69 SS 350
IZRSSS
  • Guest
Re: 69 L48 Starter
« Reply #5 on: April 26, 2011, 12:38:44 PM »
Chris,
I am not really sure when the change over occurred or if there was one (although you would think there was since the problem was brought to GM's attention on Dec. of 68). Here is a good discussion referencing these starters. Down towards the bottom of the thread you will find starter usages confirmed by Kurt. As long as your car and starter application fall within these... it should be fine.
Note; Jerry's book lists the following starters: SS350 (L48) Manual Trans-1108338, & SS350 (L48) Turbo 350-1108420
 http://www.camaros.org/forum/index.php?topic=2779.msg17843#msg17843
« Last Edit: April 26, 2011, 01:11:49 PM by IZRSSS »
crobjones2
Re: 69 L48 Starter
« Reply #6 on: April 27, 2011, 03:56:38 PM »
Marty
I believe I have the original starter for my L48 TH350 combo, 420 dated 9E12. (engine assenbly of T0525)
I have seen conflicting reports as to what the car should have come with from the factory, and have been told the 420 was a dealer replacement for the 361.
Until recently I havd never seen the technical bulletin
Guess I no longer need to search for that proper date coded 361
Chris
Chris
69 SS 350
IZRSSS
  • Guest
Re: 69 L48 Starter
« Reply #7 on: April 27, 2011, 04:45:52 PM »
Chris,
I think the credit should go to Jonsey for supplying us with the service tech bulletin.
Here's where it gets complicated...or maybe not...since the 420 & the 338 were replacements for "Hot Cranking" problems associated with the 361 it would be difficult for anyone to say, regardless of dates on these replacements, if these would be correct applications for anyone trying to assemble their L48's with "#'s parts"...just one guys opinion.
crobjones2
Re: 69 L48 Starter
« Reply #8 on: April 27, 2011, 05:50:33 PM »
I would assume at some point during the production year, only the 420 was installed on the production line.  If so, any idea as to when that may have happened?
Chris
69 SS 350
IZRSSS
  • Guest
Re: 69 L48 Starter
« Reply #9 on: April 27, 2011, 08:25:05 PM »
According to the thread I posted it seems like the jury is still out on that one. Although I hope there is enough information now so that  someone can give us the answer.
Re: 69 L48 Starter
« Reply #10 on: April 29, 2011, 01:50:05 AM »
IZRSSS
  • Guest
Re: 69 L48 Starter
« Reply #11 on: April 29, 2011, 01:58:58 AM »
Kurt,
Kurt, thank you for posting the link.
Do you have any information with regards to Chris's question? I think his question would also have to include the rest of the replacement starters. In addition, do you think the correct date as it relates to the replacements & the build date of the car pose any issues for a numbers car?
« Last Edit: April 29, 2011, 03:00:05 AM by IZRSSS »
Re: 69 L48 Starter
« Reply #12 on: April 29, 2011, 02:07:46 PM »
That TSB indicate early, so clearly before Dec 23. But they don't mention a transition date and I haven't seen it in other docs either.
IZRSSS
  • Guest
Re: 69 L48 Starter
« Reply #13 on: April 29, 2011, 02:47:52 PM »
Kurt,
Thanks again. Still a tough call since we don't have a transition date. I think the safest assumption would be (at least in my case) to find a replacement that is prior to Dec 23. At least until a transition date has been established.
I would certainly like to here from judges, officials, or other core members with your recommendations.
tom
    • Discount Internet Services
Re: 69 L48 Starter
« Reply #14 on: April 29, 2011, 04:15:29 PM »
Marty you should be able to find a local rebuilder who can rebuild any original starter to higher standards. Years ago I had the 6 volt starter on a truck rebuilt as  a 12 volt starter. Then you could have the required performance with a numbers correct starter.
69 X11 Z21 L14 glide
o
