Author Topic: 1969 z28 starter  (Read 4340 times)
wisemanz28
1969 z28 starter
« on: April 24, 2011, 05:20:53 PM »
Is a 1969 Z28 starter supposed to have a cast iron nose or a aluminum nose?
Does anyone has a pic of one , I bought one from a guy and it won't bolt up to my Z28 for some reason.
Re: 1969 z28 starter
« Reply #1 on: April 24, 2011, 05:24:00 PM »
1108367 with an aluminum nose.
Stingr69
« Reply #2 on: April 25, 2011, 12:57:56 AM »
You may have the wrong starter OR the wrong bellhousing-clutch-flywheel setup. The bolt holes are supposed to be in line, not staggered. Aluminum nose is typical. The number stamped on the steel starter case does not need to match anything.
What starter did you pull out of there before? What are the last 3 digits cast into the bellhousing? "403"? or "621"? or something else?
-Mark.
wisemanz28
« Reply #3 on: April 27, 2011, 02:11:56 AM »
Got it figured out guys , wrong flywheel
