Author Topic: Rear sub frame bolt tape  (Read 17000 times)
Boston14
Re: Rear sub frame bolt tape
« Reply #15 on: April 22, 2011, 11:28:17 AM »
Steve, John Z stated that the tape was for a water test on the Fisher Body side before the body came through to the Chevrolet side.  Therefore it was a Fisher Body operation and would not appear in the 69 AIM.  Hope this helps.
boston14
boston14
1969 SS/RS 350 Convertible
m22mike
« Reply #16 on: April 22, 2011, 12:25:15 PM »
That is correct, would not be in the AIM.
The tape in question here, you may have seen it holding the paper door water shields in place ? It was a very thin and cheap paper tape, I dought if it was anything like gaffers tape Charley. I have also found bits of it on the heater box to hold the sponge seal it place that is around the heater core outlet tubes.
re; AMK pg 176 5/8'' and 2'' black tape
http://www.amkproducts.com/Catalog_PDF/165-176.pdf
Charley
« Reply #17 on: April 22, 2011, 04:07:51 PM »
Yes gaffers tape is too thick. Here is some tape still on the rear shock hole and it is barely thicker than paper. Notice it has a sheen to it.
« Reply #18 on: April 22, 2011, 04:13:00 PM »
Quote
Charley, is that gloss or semi-gloss??
 ;D
Sorry pal, I couldn't resist.
« Reply #19 on: April 22, 2011, 04:19:23 PM »
I see there is a pic there labelled as a 69.. (Thanks M22Mike) ..but the 69 AIM (UPC 1-D1) makes no mention of the tape in it's illustration or components list.
Are we sure it's also a 69 detail?  :)
The tape used to seal that hole for water test was a Fisher Body item, so it wouldn't appear in the Assembly Manual.
BlackoutSteve
« Reply #20 on: April 22, 2011, 09:12:24 PM »
Thanks Guys.
It was Chick's 3rd post in this thread with what looks like an AIM page with tape wrapping the bushings that had me confused. I thought that was the tape in question.
Anyway, I (also?) assumed it's purpose was to hold the bushings during assembly -post Fisher. ..and didn't thoroughly read the following posts. :)
IZRSSS
  • Guest
« Reply #21 on: April 23, 2011, 01:28:38 AM »
Quote
 ;D
Pretty certain its Gloss-Semi...although the back is Flat-Shag  :-\...
« Reply #22 on: April 23, 2011, 02:26:31 AM »
Thanks Guys.
That picture Steve came with a Quanta 68 marking kit and was noted as "Technical Bullentin #69". They have several (8 or 9) of these "Technical Bullentin" numbered forms and many of them are confirmed with what I have found on our car and read what others have found. Have no idea to how correct or not on this particular bullentin #69.
