Author Topic: 1969 Z/28 - is this car the real thing?  (Read 6103 times)
huggy123
« on: April 17, 2011, 10:24:55 AM »
l am looking to buy a 1969 Z/28  the current owner has no papers but confirms the matching numbers
 block number :  V0305DZ   625880
cowl or tag number:  69  124379NOR292967
lt hasd the following codes -69
                                      -711
                                      -BU
                                      -0 3E
                                      -Bt pt
                                      -A .28
can someone help me out to confirm if this vehicle is real  1969 Z/28 before l committing to placing a deposit down
lt should be noted l am in melbourne  australia
most of the cars life has been in georgia also spending life in a collector  own collection of cars(believe it was restored to its forma glory - no panels where replaced on the  car ) 3 years and the past 2 years in florida thanks peter n n
huggy123
Re: 1969 Z/28 - is this car the real thing?
« Reply #1 on: April 17, 2011, 01:23:21 PM »
l can also add the vehicle has X77 on the cowl tag too
peter n
Mark
« Reply #2 on: April 17, 2011, 01:38:10 PM »
625880 is the VIN?
Where are all your codes coming from, seems you have so codes from a cowl tag and some from the rear axle.
cowl tag should look like:
ST 69 12347  NOR 2926967 BDY
TR 711                  69 B   PNT
03E                    X77
Need more info.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
huggy123
« Reply #3 on: April 17, 2011, 02:22:20 PM »
mark
this info is from the cowl tag on the flywall
also have the block details  V0305DZ   625880
does this help?
are you able to confirm if is a 1969 Z/28
peter n
Mark
« Reply #4 on: April 17, 2011, 04:57:09 PM »
Not without seeing a picture of the tag.
The tag is correctly dated for that VIN numbe, but there are so many fake tags out there I wouldn't even venture a guess without actually seeing it.  Does it have:
Power Front disc Brakes
a 4 speed transmission
a speedometer cable that goes thru the front edge of the transmission tunnel above the throttle linkage
12 bolt rear axle (I'm assuming that where the BU code is coming from)
4 leaf rear springs with square pads on the end of each leaf (as opposed to plastic sliders in holes at the end of each leaf)
large rear bumper guards
Open Element air cleaner
Holley 4 barrel carb
15" wheels, and a tire tag in the glove box, or on the drivers door that says 15" wheels and tires?
Dual exhaust
Thats for openers really
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
« Reply #5 on: April 21, 2011, 02:50:55 AM »
VIN is possibly on the engine pad? That's not a good thing....
tom
    • Discount Internet Services
« Reply #6 on: April 22, 2011, 02:10:35 PM »
If you want solid answers, post photos of the trim tag on the firewall, and pics of the block stamping. The experts here will tell you the truth, based on those photos. There are too many clone camaros being sold as the real deal, Z28, SS, any valuable combo becomes suspicious. Good hunting
69 X11 Z21 L14 glide
o
